1995 Mustang GT
Whats that vaccum hose called?
Okay i cant seem to find out what his hose is called or where i can find another one, anyways its the hose that runs from the vacuum tree to just inside the firewall on the drivers side, it controls the vacuum for the air switches inside, like when you switch the air from th defroster to the floor this vaccum opens the flap to switch the air, its made of plastic and mine broke, many other people have had this problem too i have noticed. but i cant figure out what its called to even do a search on ebay
thanks guys Ryan
![]() "my wheel bolts require more torque than your honda makes"
1991 Mustang LX 5.0
Just get some rubber vac line from an autoparts store and piece it together... Unless you're going for the stock/restored look.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
1995 Mustang GT
well as i do recall the line was plastic and it was pretty small, i didnt know it autozone made line that small...
1991 Ford Mustang GT
buy a rubber line that is slightly bigger then the plastic one, and slip it over each end and your done
1991 Mustang LX 5.0
I seriously used a McDonald's straw once to fix a line like that in a pince once. Just taped it over the hard line that I broke. But yes, they have line that small.
1992 Lx
11.39@119.24
good luck gettin in there without pullin the fender off
1995 Mustang GT
lol, and what exactly is that for....
Threads Similar to: Whats that vaccum hose called?
| Whats thats called? | jwallace410 | 5.0 Mustangs | 7 | May 26th, 2011 08:42 PM |
| whats its called? | crappy_head | The Clubhouse | 32 | November 1st, 2008 09:08 PM |
| whats this thing called? | ddashtrois | 99-04 | 19 | March 19th, 2008 07:33 AM |
| Whats it called? | scxc15 | V6 Mustangs | 10 | January 25th, 2008 08:07 AM |
| Whats that thing called | scxc15 | V6 Mustangs | 26 | May 4th, 2007 12:07 AM |
