LinkBack (1) | Thread Tools |
#1
1990 LX
slow
Another H/C/I intake thread.. Turbo edition!
Hey guys so after about a month of insane overtime I have some money to spend!:
![]() anyway I was wondering what you guys would recommend as a good H/C/I setup for when I eventually buy the ON3 turbo kit. I know i could buy the kit right now but i want to do the build right. I have about 2500 as a budget. I would eventually like to spin all the way up to 7k. also can the stock bottom end hold that many rev's or will she pop? thanks guys! your my heroes!! ![]() -David edit; yes i know i messed up on the title....
1992 Mitsu 3000gt vr-4: DR650 + supporting: 465AWHP 1990 mustang lx 5.0: operation no squeak; check! operation bust the stock block; underway..
1993 5.ohhhh
12.97 @140mph
Building it right prob wont happen with 2500 bucks.
when you boost, you can go budget. Gt40 iron heads, any cam you want or the stock cam, and any intake manifold other than the stocker or a bbk ssi. Just purchase valve springs that match the cam. No point and spinning a stock block car to 7000 because most likely it wont make power there, and it wont take it with boost.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
1990 LX
slow
wow so I can't get decent heads and cam's with 2500? i know i could for my vr-4 and parts are a TON more expensive...
I am very aware that 2500 wont get me the whole build. this is just the beginning. one of the many prerequisite's before throwing a turbo on the car if you will. the ON3 system will be the last thing to go on the car. I make decent money and this is going to turn into another money pit for me i think. stock is way to slowwwww. Like i said I like to build things right the first time and not have to constantly switch setups. i tried that with the 3000gt. Shit got expensive fast! also what would be a decent cam profile for a turbo system?
Atomized
i of all people apreciate doing it right but in the foxbody world things are a little differenty. My buddy has a stock bottom fox with gt 40x heads and a gt40 manifold, stock cam and the basic on 3 kit. His car dyno'd as high as 500 wheel and currently made 473 detuned on high boost. he's pushing the stock block with just those mods. And his cars a monster. If you go boost stock block save your cash for suspension and chasis you'll need it more than you know
spray and pray |
#5 | |
1993 5.ohhhh
12.97 @140mph
1989 Black LX---Turbo
Check out the Trick Flow (track) top engine kit. This set up is in your price range and should work good for what you want to do.
89 LX Black, Boss 331, C4,T76BB, FAST EFI 82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc. 73 Dart Sport 340, 410ci Bracket Brawler 72 Demon 340 4-speed 1 of 1667 01 Ram Quad Cab 03 Grizzley 660 |
Like others said, with any heads and the supporting fuel system (255 pump, MAF, and 42 injectors with a tune) and the on3 (or a SC), you can easy make 400-500. You can get a nice set of Trickflow heads and a nice holley intake and cool billet fuel rails, a full MSD ignition setup etc but they are not needed. They wont hurt but you won't need them. If you want reliability and over 500 HP and to spin past 6K.. Different story and it takes more money.
1991 Mustang LX 5.0
If you want a nice H/C/I and a turbo, maybe you should take that 2500 that you have to start your build and go buy a Dart Block. Anything above a gt40 setup and an On3 kit will bust your block unless you keep it really tame.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
#9 | |
1990 LX
slow
I already installed Tein flex coilover's all around. hence the project no squeak in my sig lol. any thing else I should look into suspension wise? thanks for all the input guys!
#10 | |
1990 LX
slow
What is the difference between a standard 302 and a dart block?
1991 Mustang LX 5.0
Dart blocks can handle more power than the average person can throw at them.
Dart SHP - 800fwhp Dart Sportmen - 1200fwhp Dart IE-2000fwhp A4-1200fwhp SVO R302-1500fwhp Boss 302-1500fwhp The Dart SHP is known to be higher capable, more in the 1000 flywheel range, and don't know where they got this number for the Boss, cuz I wouldn't push it past 12ish. And the difference is quality of metal and thickness that makes them up. And webbing (gussets).
1990 LX
slow
well thanks for the info. looks like I might as well start out just buying a block then trying to push the stocker. that dart SHP looks like what I will most likely need with my power goals.
1600 for a short block. wow. was hoping for a longblock, messing with internals make me nervous. well this sets me back. not even worth it if im going to blow the stock motor. guess I need to think about the direction i want to go with the car thanks again guys!
89 GT
That SHP should be good for around 1200hp. You're going to spend more than $1600 for just on an unmachined block if you go with an aftermarket block, unless you find one used. For a dart short with decent internals and machinework, you'll be approaching 4k (or more, depending on the parts you buy) if you buy everything new.
87 GT Vert
Here is some info on SHP vs Sportsman
Hardcore 5.0 - The Hardcore Ford Drag Racers Forum - View Single Post - Dart SHP and sportsman block
I love all my fans. |
Like stated above, $1600 is for a bare block that will require machine work. A short block will be around $4000, long block with cam, etc, $6000 range!
![]() Check on Corral.net or NMRA Racing.com, you see alot of aftermarket(Dart, World, Boss, SVO) short blocks for a reasonable price on those sites. Good Luck.
1993 5.ohhhh
12.97 @140mph
Whats your goal? If you make 460 in one of these cars with the right suspension: Strange coil overs in the front, strange shocks, a 4 cyl spring in the rear, 275 radial, 3.27 gear, a-arms, tub k member blah blah blah you can go low tens on the stock block all day.
460 can be had with a shitty hci with enough boost and not blow up as long as the tune is on point.
1992 Lx
11.39@119.24
Goals to have my hci on3 kiit car tuned next weekend so we'll see if I get my hungover ass outa bed and put my motor together today
1991 Mustang LX 5.0
Hahahaha... kids now a days. Wait a minute, if I have a hangover it takes me like 2 days to get over it... Live it up while you're young. Two nights of drinking hard is thing of the past for me.
1992 Lx
11.39@119.24
lulz I just have a lil headache, just sent orders to the gf to go get me chipotle, dunno if you know this but it has magic in it for hangovers
1990 LX
slow
450 will get me into the 10's? WOW what would the trap speed be like?
my goal was to squeak into the 10's. 6k for a built block. ouch! phares_b: thanks for the info. that is a good read!
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/220253-another-h-c-i-intake-thread-turbo-edition.html
| 500 Spin 40x | This thread | Refback | June 4th, 2011 08:20 AM | |
Threads Similar to: Another H/C/I intake thread.. Turbo edition!
| Not another Turbo Thread!! | qwiksilvermustang | V6 Mustangs | 29 | March 28th, 2011 05:57 PM |
| DUB Edition Ford Mustang Opening Salvo In Special Edition Sweepstakes | Administrator | 2011+ | 0 | May 3rd, 2010 02:03 PM |
| Special edition GTR turbo mustang with NAWZ | 95StangMX | The Clubhouse | 7 | June 25th, 2009 09:00 PM |
| MY B4 & AFTER TURBO THREAD | itschristorres8 | V6 Mustangs | 801 | September 25th, 2007 11:31 PM |
