Rear gear question
Old May 29th, 2011, 03:52 PM   #1
1992 Mustang GT
TruStangr92 is on a distinguished road
Rear gear question
Could someone please tell me what the stock rear gear was for the '92 GT? I believe it was either 3.08's or 3.27's but cannot remember which.
Thx, Dave
Old May 29th, 2011, 04:03 PM   #2
GTNBY2's Avatar
1991 GT
Never ran it
GTNBY2 is on a distinguished road
Auto or stick? different for each. my 91 auto had a 2.73 originally
GTNBY2
Old May 29th, 2011, 04:06 PM   #3
1992 Mustang GT
Oh, my bad man. 5 speed manual.
Old May 29th, 2011, 04:28 PM   #4
GTNBY2's Avatar
1991 GT
Never ran it
Pulled this from another site....
With the transmission in neutral and the car safely raised up, one turn of the rear wheels will spin the driveshaft a number of times.
2-3/4 turns would be 2.73's
3 turns would be 3.08's
3 1/4 turns would be 3.27's
3 1/2 turns would be 3.55's
3 3/4 turns would be 3.73's
GTNBY2
Old May 29th, 2011, 04:47 PM   #5
1992 Mustang GT
Thanks for the info but I am not sure how many turns it made when I had the stock gears in. I have had 3.73's in for the past few years. I thought I would be able to Google the answer but not as cut and dry as I had thought.
Old May 29th, 2011, 07:49 PM   #6
holset35's Avatar
1986 LX NOTCH
holset35 is on a distinguished road
take a sharpy draw a streight line down the driveshaft about 6 inches and count how many turns that goes around compared to the tires 1 time of going around.
86 TRUNK
359w-SRP 8:1-GT40Ps-X303-MAC LONGTUBE'S-VICTOR JR INTAKE-850 HOLLEY-T-5-410's-150 shot
Old May 29th, 2011, 08:08 PM   #7
ryanw's Avatar
1991 Ford Mustang GT
If you have 3.73 in it now why do you need to know what stock was ?
3.08 and 2.73
autos had an option of 3.27
check this link out
1990 Mustang GT, Rear gear ratio by door Code? - Ford Mustang Forums
http://wiki.answers.com/Q/What_is_th...ord_mustang_gt
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old May 30th, 2011, 12:15 AM   #8
1992 Mustang GT
I purchased a PMS from AFM and with the computer came a sheet that I fax back to them filled out with various info so that they can setup a tune for me. One of the questions is "original ring & pinion and current ring & pinion".
Thanks for the info ryanw
Old May 30th, 2011, 04:36 AM   #9
Stdyhand is on a distinguished road
My 91 GT with a T5 came with 308's but I changed it to 410's. It's not too much gear as I've heard some claim.
Old May 30th, 2011, 12:15 PM   #10
horsepowerjunkie's Avatar
1989 Black LX---Turbo
horsepowerjunkie will become famous soon enoughhorsepowerjunkie will become famous soon enough
Stock gear ratio would be 2.73 manual or auto, optional for a 5 speed would be 3.08, optional for the auto would be 3.27.
89 LX Black, Boss 331, C4,T76BB, FAST EFI
82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc.
73 Dart Sport 340, 410ci Bracket Brawler
72 Demon 340 4-speed 1 of 1667
01 Ram Quad Cab
03 Grizzley 660
Threads Similar to: Rear gear question
Rear End gear change Speed Cal Question? redrider123463 2005 - 2010 3 April 4th, 2011 05:35 PM
Rear Gear Question 07GTconvertible 2005 - 2010 22 November 15th, 2008 08:46 AM
rear end gear install question Tmac3320 99-04 38 September 25th, 2008 06:32 PM
Rear Gear Noob Question ssdell3 99-04 9 September 29th, 2007 01:32 AM
Question about Rear Gear 3.73 or 4.10 ? Xtra 2005 - 2010 8 December 31st, 2006 02:39 PM
