got a gt40 tubular intake
Old May 30th, 2011, 02:15 AM   #1
1990 ford mustang GT
bennyjet846 is on a distinguished road
hey guys,
got the gt40 tubular intake for 100 bucks! bad news is i didn't notice a hairline crack in the lower intake manifold. can that be fixed by a machine shop? the upper intake is in great condition though.
Old May 30th, 2011, 02:28 AM   #2
fogged306's Avatar
89 GT
Even if it can't, GT-40 lowers are a dime a dozen. It's the upper that's worth the big money.
Old May 30th, 2011, 02:34 AM   #3
302Army187's Avatar
'89 LX 'Vert
10's or bust... Literally.
302Army187 has a spectacular aura about302Army187 has a spectacular aura about
also jbweld might work yo
H/C/I 302 + nitrous for now... supercharger/turbo soon?
www.youtube.com/Xarmy187
Please support my YouTube channel! My videos don't disappoint!
Old May 30th, 2011, 02:35 AM   #4
yea bro. that's what i was thinking exactly. ebay is selling those uppers for 300+ bucks and mine has the plate cover. now gonna have to call up some junkyards and find me a lower gt40 to go with that upper
Old May 30th, 2011, 02:38 AM   #5
are u serious about the jb weld? if u think it'll work i'll give it a shot. the crack isn't that bad, it's just they tried to do some outside welding onto it that made it look sorta ugly and bubbly. man, i'm too blind to even spot that. i could've offered the guy 75 bucks for that problem.
btw army, i saw most of ur vids on youtube. man your car pulls like a m*fucker! good job bro
Old May 30th, 2011, 09:22 AM   #6
302Army187's Avatar
'89 LX 'Vert
If I was going to try jb weld, I would first torque the intake down to the car, slap the JB weld on there, and let it sit for 24/48 hours.
then pull it off, and get any areas you couldn't reach while it was bolted down.
but if there are any cracks in the coolant passeges or anything, your risking that getting pulled into the motor.
so its probably not worth the risk, and would be much simpler to just find another lower intake.
Thanks for checking out my videos!
Old May 30th, 2011, 10:27 AM   #7
fogged306's Avatar
89 GT
JB weld works awesome actually. I would have no problem JB welding up and intake even if it was a crack to a coolant passage as long as you prepped it right and made sure it's fully cured before use. Once that stuff dries, it's pretty solid.
Old May 30th, 2011, 11:36 AM   #8
ryanw's Avatar
1991 Ford Mustang GT
You can always go on ebay and buy the lower intakes......the cobra, the explorer, and the tubular gt40 all use the same lower intake, there everywhere.....Like fogged said its the top tubular intake thats worth the money plus you have the cover plate that are missing on every one else's.....and by the way...your welcome
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old May 30th, 2011, 03:42 PM   #9
the cracks are only at the air passage. it looked like they had it welded but the weld looks pretty shitty to me. there's also a crack on the threads that holds the upper intake together.. i'm gonna bring it to a machine shop and see what they can do about it. can machine shops do a pressurize on the intake to make sure there's no leak coming from the coolant passage? it looks pretty clean to me but now looking it at the daytime it looks pretty beat up and like army said, don't wanna take any chances. but yea, i should really dedicate this post to ryan, thanks for the great tip man! mapquest gave me a estimated 50 minutes to get there, i got there in 38 minutes. haha.
Old May 30th, 2011, 11:20 PM   #10
ryanw's Avatar
if its going to cost more then a hundred bucks to fix then either go to a junkyard and pull one your self or just buy another lower intake, not a big deal bro...you got the best part
GT40 93 Cobra Lower Intake Manifold Ford Mustang 302 | eBay
255 fuel pump,
3:27 gears
Old May 31st, 2011, 01:40 AM   #11
how much does it usually cost to port and polish the lower intakes?
Old May 31st, 2011, 01:41 AM   #12
hey ryan, i see you're selling a lower intake bro..
Old May 31st, 2011, 02:24 AM   #13
302Army187's Avatar
'89 LX 'Vert
Mine cost $120 I think from a local guy. port matched the intake to gasket/heads, and a bit of port & polish, nothing crazy.
Old May 31st, 2011, 08:27 PM   #14
ryanw's Avatar
im not selling one, but i found one for you, thats what the link was for
255 fuel pump,
3:27 gears
Old May 31st, 2011, 10:11 PM   #15
lol my bad. i thought that was one of your signatures on the bottom.
Old May 31st, 2011, 10:43 PM   #16
ah, tmoss can't fix the lower intake cuz it's too messed up. time to buy that lower intake u linked me.
Old May 31st, 2011, 11:11 PM   #17
ryanw's Avatar
you dont have to buy that one...is was one of the cheaper ones with the buy it now option that i found, it looks dirty in the picture but should clean up great with a wire wheel and carb cleaner. Make sure you ask any questions you have to the seller before you buy. when you go to ebay just search...Explorer intake or cobra intake or gt40 intake (the lowers only) ect...... Good luck
255 fuel pump,
3:27 gears
Old June 3rd, 2011, 02:02 PM   #18
302Army187's Avatar
'89 LX 'Vert
Originally Posted by kingston123 View Post
i like your post you do good effort to make it more valuable.
thanks for sharing.
The San Antonio Express News
mustang is a one of the best car.this forum is good and interesting.
Craigslist Dallas real estate
wtf? spam bot?
Threads Similar to: got a gt40 tubular intake
Tubular gt40 intake question Stdyhand 5.0 Mustangs 20 May 30th, 2011 01:45 AM
gt40 intake/gt40 heads black05gt 5.0 Mustangs 13 March 10th, 2011 10:47 PM
Wanted: GT40 Tubular Intake fmaster7 5.0 Mustangs 16 March 14th, 2010 02:39 PM
custom gt40 tubular intake pyrofenix 5.0 Mustangs 25 November 3rd, 2007 12:28 PM
