crank bolt?!?
Old May 30th, 2011, 04:05 PM   #1
1988 convertible's Avatar
1988
1988 convertible is on a distinguished road
Send a message via Yahoo to 1988 convertible
crank bolt?!?
Hi guys,
Anyone know how i can remove the crank shaft bolt without the use of an impact driver??
Old May 30th, 2011, 04:08 PM   #2
fogged306's Avatar
89 GT
Is the engine in or out of the car? If it's in the car is it a stick?
Old May 30th, 2011, 04:11 PM   #3
brandon444's Avatar
91 Mustang LX 5.0
brandon444 is on a distinguished road
If it's in the car
Auto, you'll have to take off the inspection plat and use a screw driver to block the flex plate
Manual, Just put it in 5th
Old May 30th, 2011, 04:33 PM   #4
1988
hi guys,
the engine is in the car, using an auto box
Old May 30th, 2011, 09:07 PM   #5
nolife's Avatar
91GT, 88GT, 02GT
And if the front is up on stands/ramps/jack, have someone hold pressure on the brake pedal because it will move forward.
Old May 30th, 2011, 10:04 PM   #6
brandon444's Avatar
91 Mustang LX 5.0
Originally Posted by 1988 convertible View Post
hi guys,
youll have to take the inspection plate off the front of the trans and I used a screw driver wedged in between the subframe and one of the holes in the flex plate
just be careful not to damage amything
Old May 30th, 2011, 10:42 PM   #7
1992 Lx
11.39@119.24
15/16s socket
if you have a friend thats not a weak pansy he can hold the crank pulley from underneath and you can break it loose with a breaker bar
dont have friends breaker bar+pipe on the end touching the floor+bump starter
Old May 31st, 2011, 12:04 AM   #8
ryanw's Avatar
1991 Ford Mustang GT
strap wrench on the pulley and 15/16 on the bolt
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old May 31st, 2011, 04:06 AM   #9
1988
thanks for the replies guys
sadly im on my own wouldn't trust my friends to open a tin of beans let alone hold the H-Balancer hahahaha
will have a look at the wedging a spanner option that sounds more my style *brute force* grrrrrr
Threads Similar to: crank bolt?!?
8 bolt crank in a 00 gt?? TheLubracano 99-04 15 September 24th, 2010 11:52 PM
crank bolt. 07 STROKER 2005 - 2010 16 May 23rd, 2009 03:54 PM
crank bolt moosenuk17 99-04 8 April 18th, 2009 06:04 AM
HELP! SOHC 6 bolt crank/ cobra 8 bolt crank interchangability? the1968jeepthing 99-04 2 September 29th, 2008 11:39 PM
