1992 Mustang LX
13.8
Anyone have experience with e85?
i recently converted my car over it was running great until it was acutally switched to e85 (it was e70 until about a week ago) i was curious if anyone else had switched over.
probelms are loss of power it seems like and lots of bucking. im not sure what to do about it at this point any input is great thanks im guessing it needs to be tuned, but a second opinion would help LOL
![]() 70mm TB, 75mm MAF, BBK CAI, Edelbrock upper and lower intake, 30lb injectors, Port/Polished E7 heads, some cam, bbk short headers full flowmaster exhaust with H pipe RUNNING ON E85
1991 Mustang LX 5.0
Did you get a tune for this? Is your fuel pump and injectors sized properly? Takes more ethanol to do the same job, but the btu's is actually higher when you compare the correct desired A/F ratio between the two. You should actually see a slight bump in power.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
1993 5.ohhhh
12.97 @140mph
Sounds like you kept everything the same and started pumping ethonal in it...
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
1992 Lx
11.39@119.24
why you have stats from someone else driving your car???!?!?!
1989 Black LX---Turbo
Sounds like its running lean. E85 requires aprox. 30% more fuel than regular gas. We've been running E85 in my son's bracket racer for the past couple years. We sent the carb to Pro Systems for the conversion. The carb is jetted big, the squirters are big and it uses a gallon every pass!
89 LX Black, Boss 331, C4,T76BB, FAST EFI 82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc. 73 Dart Sport 340, 410ci Bracket Brawler 72 Demon 340 4-speed 1 of 1667 01 Ram Quad Cab 03 Grizzley 660 |
1993 5.ohhhh
12.97 @140mph
When you ball like me, which you don't, you can do that
1992 Mustang LX
13.8
thanks for the responses guys it was running lean i wasnt running enough fuel pressure. dumb mistake lol.
for the record i didnt just start pumping e85 in it.i put in new injectors, mass air meter, fuel pump, fuel pressure reg., and fuel filter.
1991 Mustang LX 5.0
Still need a tune for it. Computer can't compensate for it. It's not a flex fuel vehical.
1992 Mustang LX
13.8
i know i just dont have the money for it at the moment hopefully in a few weeks i will (just got my job back this week) it run like shit when i first start it but after running for over a half hour it starts running perfect. i can only assume its because its not tuned.
is getting the sct chip a bad idea? its what my local tuner reccomended i get.
Threads Similar to: Anyone have experience with e85?
| anyone have any experience with this? | 707Stang | Classic Mustangs | 11 | January 29th, 2009 12:14 PM |
| anyone have any experience with this? | 707Stang | Classic Mustangs | 0 | January 28th, 2009 07:45 PM |
| Does anyone have any experience with IRS in a Fox? | Evil Intent | 5.0 Mustangs | 1 | January 15th, 2008 03:24 PM |
| Does anyone have any experience with IRS in a Fox? | Evil Intent | General Tech | 6 | January 11th, 2008 02:12 PM |
| Anyone w/SVO experience? | sweet99 | 96-98 | 4 | November 7th, 2007 05:34 PM |
