k&n filter dimensions
Old June 1st, 2011, 06:07 PM   #1
5.0 lover is on a distinguished road
i was wondering if any of you guys know the dimensions for a universal cone k@n filter that just clamps on the stock maf sensor for my 91 gt, so that its basically a ram intake.
Old June 1st, 2011, 07:45 PM   #2
ryanw's Avatar
1991 Ford Mustang GT
you dont want an open filter in the engine bay, because it will pull in all the heat from the engine, which will result in less horse power, I think you would be better off keeping the stock air box, it is a form of a cold air intake because its pulling air from the fender not the engine bay
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old June 1st, 2011, 11:26 PM   #3
wont it still be better than a crappy paper filter in a stock air box
Old June 1st, 2011, 11:46 PM   #4
ryanw's Avatar
you can buy a K&N filter in the same shape as your stock filter...it fits right inside the stock air box....thats what i have
255 fuel pump,
3:27 gears
Old June 1st, 2011, 11:58 PM   #5
ryanw's Avatar
86-93 Mustang Thunderbird Cougar MK 5.0 Ford Air Filter | eBay
K&N AIR FILTER 33-2015 MUSTANG 5.0L 86-93 | eBay
255 fuel pump,
3:27 gears
Old June 13th, 2011, 01:50 AM   #6
1990 ford mustang GT
bennyjet846 is on a distinguished road
man this sucks, i'm finding out i'm buying a lot of shit over again. i got the stupid k&n filter.. i need to get the one that goes inside the fender. good information as always ryan.
Old June 13th, 2011, 05:12 AM   #7
PsyAbe's Avatar
'92 LX
PsyAbe is on a distinguished road
Send a message via AIM to PsyAbe
+1 on the drop-in k&n filter. It's essentially all we need for cold air. All the other fancy shmancy tubing etc is just for show really, and the hp gain from them when compared to the price is just a joke. The only apparent advantage of a ram intake is that it sucks in more air due to it's larger size, but frankly I don't see the point since that air is hot. Colder air from outside the fender is denser and thus better than whatever mass the ram air can take in since it won't be as dense due to its higher temperature. If I was hellbent on getting an aftermarket intake I'd probably go with a powerpipe, at least it sucks in air from the outside and the tubing is actually wider than stock, unlike all the other stuff.
Old June 14th, 2011, 01:40 AM   #8
i'm lookinag at the numbers from dynomyth and it's a pretty good difference in power for a cold air intake.. the question is.. i got that k&n conical one... i'm really thinking about getting the one that goes in the fender.
Old June 16th, 2011, 01:26 AM   #9
ryanw's Avatar
There is advantages to having an after market cold air intake, some time the tubing is bigger, it has smooth pipe unlike our stock tubing, but some of the aftermarket cold air intakes come with filters that are way to small..
I would buy one my self but in a year ill be supercharging, so the cold air intake with be of no use to me at that point since in will have to removed for the supercharger.....Im kind of done with throwing money away
255 fuel pump,
3:27 gears
Old June 16th, 2011, 11:50 PM   #10
same here ryan. when i bought the mustang mid last year i was putting shit on left and right without really doing research. and most of them i had to redo all my work. about 3 months ago i had to drop my tranny down again to put a stall converter on it after wrong information the transmission shop had given me.
Old June 17th, 2011, 01:11 PM   #11
baine21225's Avatar
Oh yeah? I'd like to hear your logic behind that. But in the mean time, stop saying dumb(and incorrect) things like this.
Your best bet is to just get a no name fender well kit from ebay for $25-$50 and then replace the filter with a K&N one. All of that fancy smancy tubing will net you a few more hp than a stock replacement drop in.
Old June 17th, 2011, 01:22 PM   #12
I Poop Entirely Way Too Much
Blown 03 GT
03_StangGuy is just really nice03_StangGuy is just really nice03_StangGuy is just really nice03_StangGuy is just really nice
Or you can build a fender intake with some pipes from here, Intercooler Pipe Fabrication - Silicone Intake Systems Auto Parts
Threads Similar to: k&n filter dimensions
roll bar dimensions prostrtstang 2005 - 2010 29 October 1st, 2009 03:24 PM
storage? dimensions? oscrfsh 5.0 Mustangs 3 August 13th, 2009 09:42 PM
Dimensions SLP exhaust 04BlackGT 99-04 2 May 27th, 2009 04:44 AM
procharger air filter dimensions or part number please? B0B 99-04 6 July 29th, 2008 12:35 AM
Tire dimensions? mineralmustang05 2005 - 2010 2 February 3rd, 2008 10:40 PM
