none roller lifter change.
Old June 2nd, 2011, 05:32 AM   #1
78mach1's Avatar
78mach1 is on a distinguished road
Send a message via MSN to 78mach1
ok so i have a 78 302 that has a few bad lifters, the motor itself only has about 10k miles on it....
my question is is it safe to swap just the lifters and not the cam?...i have always heard that flat tapped lifters wear to the cam lob and switching them out can sometimes whip out a cam lob.
thanks let me know.
Old June 3rd, 2011, 05:22 AM   #2
78mach1's Avatar
bump
Old June 3rd, 2011, 08:19 AM   #3
FastStang91Lx's Avatar
1991 Mustang LX 5.0
Your title says roller in it, but you say flat tappet in the post. Which one do you have? If it's roller, you can change it out, if it's flat tappet, I don't have a clue since all I know is what you already know: They wear in together.
Old June 3rd, 2011, 01:53 PM   #4
78mach1's Avatar
"none roller" = "flat tapped.........
Old June 3rd, 2011, 01:55 PM   #5
78mach1's Avatar
i pulled all the lifters and im not able to compress any of them.... is it possible that they all are seized?
this motor has been sitting since about 2009.
Old June 4th, 2011, 12:09 AM   #6
'88 Mustang GT
DigitalDC89 is on a distinguished road
Send a message via AIM to DigitalDC89
"non-roller" = "flat tappet".........
google searching for like 2 minutes showed that most people recommend replacing the cam with new lifters, and vice versa.
'02 Mustang GTm Convertible - N/A Cammed Daily
'88 Mustang GTm - 1/4 Mile Build - 750rwhp Project
'97 Saturn SL2m - Ex-Nitrous Build - Back-Up Daily
Old June 4th, 2011, 12:32 AM   #7
ryanw's Avatar
1991 Ford Mustang GT
convert it to a roller
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old June 4th, 2011, 04:44 PM   #8
78mach1's Avatar
its kind of a budget car that im putting together for my girl friend, and i dont wanna spend alot. i just think its highly unlikely that all the lifters are seized.
Old June 4th, 2011, 05:26 PM   #9
1992 Lx
11.39@119.24
thought they were solid?
Old June 4th, 2011, 06:52 PM   #10
ryanw's Avatar
if every time lifter wears.....you have to replace a cam, then it doesnt sound like a budget.....i know that doest happen to often, but still....
i still say covert
255 fuel pump,
3:27 gears
Threads Similar to: none roller lifter change.
Setting adjustable roller rockers on hydraulic lifter motor BlownSmoke 94-95 1 May 19th, 2011 06:49 PM
roller lifter roller-5.0 94-95 1 May 19th, 2010 04:15 AM
solid roller lifter vs. hyd flat lifter ... pushrod length? ryans88gt 5.0 Mustangs 5 December 10th, 2008 12:19 AM
Hydrolic roller to Solid/Mechanical roller hitorx 5.0 Mustangs 2 May 14th, 2007 05:12 PM
