LinkBack (1) | Thread Tools |
#1
1991 mustang gt
roller rocker question
ive got gt40p heads and a e303 cam for my 91 gt i wanna put some roller rockers on it but dont no what to look for or what would work best needing some help thanks
1989 Black LX---Turbo
I always use 1.7 roller rockers with the E303 cam, if your springs are up to it. If you are going to use the E303 cam you should have upgraded springs anyway. Thread below.
89 LX Black, Boss 331, C4,T76BB, FAST EFI 82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc. 73 Dart Sport 340, 410ci Bracket Brawler 72 Demon 340 4-speed 1 of 1667 01 Ram Quad Cab 03 Grizzley 660 |
1991 Ford Mustang GT
i think you need pedistel mounted rocker
1992 Lx
11.39@119.24
pedestal mount rockers are fukin retarted. Oh no cant adjust them shim shim shim
^^^ ya i was thinking it might be a waste of money unless it was coverted over to stud
To the OP, just wanted to make sure you didnt buy the wrong type of rockers
1991 mustang gt
for the money will they make that big of a diff?
'89 LX 'Vert
10's or bust... Literally.
meh. maybe.
going from 1.6 to 1.7 should yeild power if your heads can support more lift/RPM. I wouldn't invest in it if it was me though. If you plan on upgrading to a better cylinder head, then it will just be money lost, on a very small gain in power
H/C/I 302 + nitrous for now... supercharger/turbo soon? ![]() |
#8 | |
i'd strongly advise staying away from the proform rockers... |
he wants to go with stock gt40 heads
1991 mustang gt
i have gt40p heads and ive put new valve springs in them already but im going to get some trick flow heads later so i guess id be better off to wait thanks for the help guys
if you get the trick heads you can get their signature 1.6 rockers, i know allot of guys that swear by them...
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/221165-roller-rocker-question.html
| Thread roller rocker question | Forums at Modded Mustangs | BoardReader | This thread | Refback | April 4th, 2012 07:42 PM | |
Threads Similar to: roller rocker question
| roller rocker ?' | Sally845 | 5.0 Mustangs | 8 | January 17th, 2011 07:41 PM |
| Roller Rocker Arm Kit | scxc15 | V6 Mustangs | 24 | January 25th, 2008 08:09 AM |
| Roller Rocker help | sniperrider | 5.0 Mustangs | 12 | August 31st, 2007 10:00 PM |
| roller rocker ? | marcd | 5.0 Mustangs | 15 | June 25th, 2007 10:35 PM |
| Valve Cover/Roller Rocker Question | 5-0stank | 5.0 Mustangs | 11 | March 13th, 2007 09:43 PM |
