wiring harness
Does anyone know where the heck i can find the short harness that connects the O2 sensors to the main harness.. It is a short "Y" harness.
This is for an 86 and seems to be impossible to find for that year. |
Big timin' in a small town
Could you get it from late model resto, mustangs unlimited, or cj pony parts havent checked but theres th places that I would check
found them
your in luck !
i just did the same thing to my 86 5.0 and yes i found a place to buy them , did it about 2 months ago and it fit great and worked i found a guy who makes them new. email me i will have to look it up and find it, just changed computers and do not have info on this one so i will look it up on old pc when i get a chance chadjones99@hughes.net
1986 stang ,Edelbrook intake, aluminum heads, E303 cam ,70 MM throttle body ,24lb injectors ,373 gears , 10:1 pistons set up,no cats , flowmaster mufflers , short shifter , 255 fuel pump , smog pump delete , A/C delete , Aluminum Radiator , MAF convertion |
got o2 sensors here :
still looking for harness will get back asap
here it is this is were i got mine
http://www.qualityautospecialties.com/cart/index.php ok i do not see the 86 listed but this is were i got mine , i had to call them its hard to find on thee site
If u can find one in a 86-93 5.0 they will fit it. I would check a junk yard.
I know that 86 is a stand alone wiring harness... 87-93 had a different O2 sensor wiring.. The 86 uses 3 wires and 87-93 uses 4 if i am correct... however I do know forsure that the plug heads are of a different size between the 86 and later ones.
But thanks everyone for the help... much appreciated |
Nah my O2 harness fits perfect wit the 91 wiring harness that I put in it.
why get one from a junk yard. i mean unless there is a money issue. i had to replace mine because of age, so i got a new one and it works great.
also there is a diffence on 86 than 87-93. the plug looks the same but it is clock diffent. i tried this all ready
Well mine fit perfect with the 91 5.0 harness I put in my 86 and the computer reads it so I dont really know why ur wouldn't fit.
20 year old wires !!!!!!!!!
well there maybe some truth to that. i think if ( and i was told this so i dont know ) you put the 87- up harness on it will work if you also go with 87- up O2 to match.
good luck. I would not buy any wires from a junk yard unless i HAD TO. if you can get them new i would .And you asked if anyone knew were to buy them so there you have it. I did the leg work for you and gave you a website and a link to the new O2's at a great price. Like i said I just did this to my 86 and it worked fine. ( side note i am running a 89-93 PCM my car has had the mass air convertion ) I said that just because it shows that the computers probly dont care what harness you get as long as all the wires match up. 86blkmustang did it to his 86 with parts from a 91 so i pretty sure the pcm's are good with it. and mine has a newer PCM. but i just did not want used 20 year wires.
Threads Similar to: wiring harness
| 2.3 Wiring Harness | bjbostian | 2.3 Mustangs | 2 | March 6th, 2007 12:19 PM |
| Wiring Harness | 86blkmustang | 5.0 Mustangs | 1 | February 10th, 2007 05:14 PM |
| wiring harness | doorvip | 2.3 Mustangs | 1 | December 29th, 2006 03:22 PM |
