Problem with rear axle offset....is there a fix??
Old June 6th, 2011, 03:19 PM   #1
1990 Mustang GT
rocket is on a distinguished road
So I lowered and thru some new wheels/tires on and the passenger rear rubs, as it sticks out noticably more than the drivers. Is there a way to pull the axle back to even this out.....like with adjustable control arms or will that not work?
Scared to roll the fender as I don't want to screw up the original paint.....but afraid I might have to.
Does anyone know if there is a way to have someone shave the inside of the rim to pull it in the wheel well to even it that way, or is that just crazy talk?
Any help/ideas welcome, as I want to keep it lowered as it looks kick a$$, but cant have it rubbing.
'90 GT
Vortec SI with pro-pipe
Eibach pro kit
KYB adjustable shocks/struts
BBK headers/x-pipe/american thunders
Old June 6th, 2011, 07:09 PM   #2
Av8tor is on a distinguished road
Should be pretty safe to roll the fenders if you get the tool for it and follow all the instructions.
Old June 6th, 2011, 11:10 PM   #3
1990 Mustang GT
when rolling the fenders tho, does the paint chip easily? Im worried bout it chipping and pealing.
'90 GT
Eibach pro kit
Old June 7th, 2011, 11:23 AM   #4
1988 Mustang LX 5.0
NT_Hardcore is on a distinguished road
if your going to do it, roll them on a hot day. paint will soften up a lil and not be a prone to crack-
No more stang crew
"TAMPA BAY AREA CREW"
Old June 7th, 2011, 11:35 AM   #5
Most how to videos ive seen shows them using a heat gun to warm up the paint a bit to help prevent chipping, just not too much heat.
Old June 7th, 2011, 12:08 PM   #6
95tbirdv8's Avatar
1990 mustang gt
95tbirdv8 is on a distinguished road
they make it look easy. i just hammered mine, and the paint chipped but only on the inside, so you cant see it outside.
Burning Rubber in the 5.0
http://www.youtube.com/watch?v=mKGSmRkKQcM95
95 mark8 lsc 95 tbird v8 90 mustang gt 07 silverado v8 08 yamaha r6
to be continued........
foxbodyperformance.com is the way to go
Old June 7th, 2011, 12:30 PM   #7
1988 Mustang LX 5.0
i use a baseball bat normally, gets the job done and hasnt failed me yet.
No more stang crew
Threads Similar to: Problem with rear axle offset....is there a fix??
Swap 7.5 rear axle for an 8.8 Axle. Kjb135 V6 Mustangs 18 May 3rd, 2011 12:26 AM
Rear axle width problem 87periman 5.0 Mustangs 2 August 1st, 2010 09:02 AM
Rear end offset...Problem? hippojumqer 99-04 6 April 27th, 2010 08:47 PM
Wheel Offset Chart (covers high offset and wide wheels) CadVetteStang Visual 1 August 29th, 2009 08:45 PM
Rear Rotors and Rear Axle rondaw3g0410 99-04 1 September 6th, 2006 10:00 PM
