disconnected vacuum lines - Forums at Modded Mustangs
post #1 of 4 Old June 7th, 2011, 04:56 PM Thread Starter
first off i dd a 92 5.0 lx
and i found my vacuum leak. its a thin black hose running from behind the intake between the engine and firewall. im not quite sure what it does but its not connected to anything at all
i also have a ton of other vacuum lines that id like to connect. im not too hip on all the vacuum line lingo so diagrams are difficult to read and apply
can you guys help me pinpoint what each line in the harness does and where it may go? also im in ca so i need to be a able to pass smog. do any of these affect emissions?
'75 Chevrolet Chevelle Laguna Type S-3 - SOLD
'88 Mustang GT Hatch
MallyMall7 is offline
post #2 of 4 Old June 7th, 2011, 05:13 PM
The first line goes to a black check valve on the firewall, close to the hood hinge on the passenger side. The others go to smog pump and other stuff, I'd have to walk you threw those.
DShort is offline
post #3 of 4 Old June 7th, 2011, 06:41 PM
95tbirdv8's Avatar
does your car still have the smog pump? I see the thick hose that goes to it in the picture. i cut those same black and white lines on mine and capped them off when i bypassed mine.
Burning Rubber in the 5.0
http://www.youtube.com/watch?v=mKGSmRkKQcM95
95 mark8 lsc 95 tbird v8 90 mustang gt 07 silverado v8 08 yamaha r6
to be continued........
foxbodyperformance.com is the way to go
95tbirdv8 is offline
post #4 of 4 Old June 8th, 2011, 10:07 PM
try this diagram its for an 88 gt so it will help http://www.veryuseful.com/mustang/te...g5.0Vacuum.gif
also this site has a ton of goodies.
Mustang FAQ - Wiring & Engine Info
hope this helps.
FROMxAxDIG is offline
Human Verification
