1990 Mustang GT
MAF sensor testing
I watched a video on youtube about testing MAF sensors with a multimeter.It says you should see 12volts with the key on \motor off and if you see lower you have a different problem because the maf won't work unless you have 12.I'm seeing 11.5 volts.Where should I start looking for the problem?
1990 mustang gt
is your car having problems, or you just want to test the maf sensor? When you got 11.5v at the maf, what voltage did the battery have? if you had the key on engine off along with accessories on the voltage drops. so i think 11.5v would be normal.
Burning Rubber in the 5.0 http://www.youtube.com/watch?v=mKGSmRkKQcM95 95 mark8 lsc 95 tbird v8 90 mustang gt 07 silverado v8 08 yamaha r6 to be continued........ foxbodyperformance.com is the way to go |
1990 Mustang GT
I'm having problems.
The battery has 12v. The key was on no accessories.I just found a more in depth maf testing video so I'm going to try it out.Don't have a scanner yet.
1990 mustang gt
you dont need a scanner. you can use a test light, or just count how many times the check engine light turns on.
DIY KOEO/KOER/Cylinder Balance Self-Test Procedure
Threads Similar to: MAF sensor testing
| P0141 O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 2) | Shaun03GT | 99-04 | 23 | March 19th, 2011 12:08 AM |
| ~Testing, Testing~ DMC-FZ28 10mp 18x Optical | TheUNZippee! | Pictures | 12 | January 18th, 2010 09:32 PM |
