1989 GT Hatch
they remove the drive shaft right?
they remove the driveshaft when they do a gear swap right. got gears last weekend and now 2 drops have leaked out of my transmission seal.
yes
9000 hp, 170 knots, 9 aluminum drive shafts, 3 piston disk brakes, can carry 9 camaros to the junkyard at the same time. |
#3 | |
Re: they remove the drive shaft right?
1990 LX hatch
I put in a new seal everytime I take out my shaft...[/quote]
+1. I don't, but I wish I could say I did.
#5 | |
Yeah... I knew that was coming as soon as I hit the submit button..
1989 GT Hatch
i tried to make the shop do it for free, but they wouldn't so i guess i'll do it myself.
As a mechanic, I can tell you that technicaly the shaft does not have to come out of the tranny. Most of the time people will take the extra 2 seconds to pull it out but you can just take the 4 bolts out of the rear end and the shaft will hang about 2 feet out of the way. I always check the seal prior to taking the shaft out and if there is any doubt i replace it. They are a dime a dozen and frequently leak.
1989 GT Hatch
The "how to" isn't in my chilton's, can anyone tell me how? sounds like it's easy, but i don't want to go into it blind. thanks.
remove the driveshaft, GENTLY pry out the old seasl and tap in the new one till its flush, smear a small amount of grease and re-install the driveshaft. be sure you tap it in a little at a time around the seal
"The gods too are fond of a joke." "If I had only known, I would have been a locksmith. " |
Threads Similar to: they remove the drive shaft right?
| drive shaft shop one piece steel shaft ok for automatic tran | mustang fanatic | 2005 - 2010 | 8 | September 24th, 2007 01:21 AM |
| drive shaft | scxc15 | V6 Mustangs | 28 | September 6th, 2007 06:20 PM |
| drive shaft ? | Drgnracin72 | 99-04 | 2 | April 13th, 2007 10:26 PM |
| HELP!! how do i remove the crank shaft pulley?? | Onemanzu | V6 Mustangs | 12 | December 30th, 2006 01:47 PM |
