Common alternator debate/decision???
I'm sure people have ran into this situation once or twice when modifying their vehicle. And I need a good answer/advice if someone is willing to help
lol...haven't been up here in a while but another fox brought me back ....anyway I have a fox 5.0 fuel injected...h/c/i...aftermarket cap/rotor/distributor...crane ignition...yellow top optimal battery....no power steering...no ac...no smog...no speakers....no radio...no interior lights except for instrument panel and gauges...still has power locks/windows/mirrors.....still use outside lighting/wipers...basically its still a street car even tho its not daily driven....it has nitrous solenoids in it but even the nitrous is currently not hooked on possible future installation but not right now so that's really nothing of concern right now....it has a single wire altenator that just went during normal street drive...Its an aftermarket altenator but there is no engraving or stamp indicating the output of the altenator....some shops or people are telling me I might need sumtin like 100amp but I don't see the real need because its not like I'm tryin to ride on 40 inch rims 10 tvs and 25 speakers...the stock one is a p.o.s but I really want something that I can have on there for a while and can still be streetable....that's I believe all these higher output altenators like the 3g upgrade is just too much....I'm not tryin to have a bonfire either with it lol....any help or advice from u fellas/ladies would be highly appreciated!
89 Mustang LX Hatch
95 amp from PA performance can be had from Mustang Parts, Chevy Truck Parts & Dodge Challenger Parts at Latemodel Restoration Supply I would recommend the 130a but you have to modify the alternator bracket. The 95a is a direct bolt in and will be plenty for your needs. I'm running that unit myself.
Thx for your input man!
89 Mustang LX Hatch
No prob, If you ever do decide to run an electric fan / radio with amp(s) and speakers, then you might need to upgrade to the 130A. The 95A is good for your car though. I think it would still be ok even if you had underdrive pullies.
89 GT
One thing you have to realize is that the amperage rating of an alternator isn't what it puts out at idle. It's at peak RPM's for the alternator. So at idle you aren't pushing close to 100A with a 100A alternator. At night with the lights on and the heat on full blast, you can be drawing quite a bit of amperage at idle. Throw an electric fan in there like mentioned above, and it's even more. The stock alternators were pretty weak from the factory and if you're already one wire, I wouldn't take a step backwards and change it back to a stock type. You can never have too much alternator, they all have voltage regulators. If the battery starts to overcharge, voltage goes beyond what the regulator is set for and the alternator stops charging.
SVTfocus, F250
just hit your local junkyard and pickup a 96+ mustang alternator. its the 130a stocker. usually run for 35$. i put one on my fox and havent had any problems with it.
1991 gt vert
dude, just put a j/y 3g alt on. like mxnate116 said they are about $35 bucks at the j/y. your allready wired for it. i have had 0 problems after doing the swap.
89 Mustang LX Hatch
The good thing about the PA performance one is the lifetime warranty. But as mentioned, you can't beat a $35 j/y 130a.
94 swap
Swap in a '94 alternator. Did it in my '89, most cost effective way to get a more powerful alternator. Below is a walkthrough.
The 3G Alternator Project |
SVTfocus, F250
Screw the lifetime warranty, if the junkyard alt goes out you can buy 4 more before you hit the price of the 90amp alt
89 Mustang LX Hatch
That's only if all 4 work, there's no guarentee at the junkyard. Plus I wouldn't want some rusty POS in my engine bay. I'm set for life now.
98 Cobra
SVTfocus, F250
all the yards around here have a warranty that says theyll at least work, hell im pretty sure they were tested. and mine looks brand new.
1989 mustang lx
i just got mine from the junk yard it was 35 with a 30 day warranty and before i put it in i had pep boys test it
89 Mustang LX Hatch
That's good if you can find a decent donor car. I don't go to the yard that often because there's just so much junk. Where I go, you pay $40 and you can grab as much shit as you can carry, no warranty though. Either that, or you pay by the part if it's too heavy to carry. Do your junkyards really give warranties on all parts, motors included? Around here we have to check the motor, usually can tell if it's bad by the fluids, but still no warranty.
#16 | |
90 GT
It was a fucking nightmare. What killed it for them is they argued with me over and over and over, about how it could not happen. Then the one guy said he was going to send me a new voltage regulator (since I'm using the one from the original that seized it bearings) and they never did.
Rewarding our friends, punishing our enemies. |
#17 | |
SVTfocus, F250
90 GT
Thats not always the case. Sometimes they give you a guarantee that its not DOA when you install it. Check with them...
89 Mustang LX Hatch
Yeah, I've only been to the pull it yourself yards, lol. Only been to two differenct junk yards before too. About the PA performance thing. I'm sure if you kept nagging them, eventually you would have gotten what you wanted. Persistance is key.
#20 | |
89 GT
Threads Similar to: Common alternator debate/decision???
| Most common 5.0 built? | bennyjet846 | 5.0 Mustangs | 16 | July 13th, 2010 11:25 PM |
| Something in Common... | oldernewbie | The Clubhouse | 3 | February 21st, 2008 01:24 PM |
| Most Common Gear ? | Montanasvt | 99-04 | 19 | February 12th, 2008 10:31 PM |
| Common guys | Juggalo_X | The Clubhouse | 19 | September 5th, 2007 06:38 PM |
| Is This Common? | mustangmanic | 99-04 | 17 | July 7th, 2007 04:49 PM |
