MAF questions ?
Old May 11th, 2007, 06:24 AM   #1
Smoph is on a distinguished road
MAF questions ?
I am running a 1988 stang with BBK SSI intake system a 75 MM TB and full exhaust system (long tube headers FM exhaust ) i dont have the MAF hooked up yet but i wanted to know the size i needed
Thanks for the help
i have intent to cam it with a 270 comp cam and some AFR's what you all think
Old May 11th, 2007, 11:20 AM   #2
twinturbo is on a distinguished road
Get a C&L, 75mm, I believe.
Old May 11th, 2007, 10:15 PM   #3
Red Hot 92 is on a distinguished road
I am running an 80mm off an '01 cobra ($65.00 e bay). I know several Ford models used the plastic housing 80mm style sensor. I had to change the connector and wire terminals to the newer style, and fab an adaptor for my intake duct air filter side. It works great. My tuner wanted me to stick with a Ford sensor, due to accuracy and less variation. Another thing he pointed out is the upper cold air inlet tube (BBK or MAC) Mass air to t.b. is smaller in diameter than the stock rubber Ford piece. I took the BBK upper section off and used a factory Ford tube. It's a bitch, but the Ford intake tube will stretch over that 80mm mass air.
Old May 11th, 2007, 11:43 PM   #4
Stangzilla's Avatar
Stangzilla is on a distinguished road
I would stay away from C&L if I were you. Look into a Pro-M or Granettelli or something like that. Get a 70-75mm..
Today, I found out that when I masturbate at night while watching internet porn I cast a huge shadow on the curtain and the entire street is able to see it.
Threads Similar to: MAF questions ?
Few Questions Bies08 V6 Mustangs 12 August 21st, 2007 11:33 PM
rim questions SilverGT04 99-04 26 August 17th, 2007 02:54 AM
*a few questions* mustang1072 V6 Mustangs 10 June 29th, 2007 12:59 AM
Questions about new car! Blown93Cobra 5.0 Mustangs 6 June 4th, 2007 04:45 PM
2 Questions mikethetigerrr V6 Mustangs 21 October 25th, 2006 10:23 AM
