Strange Smog Crossover pipe to EGR valve setup
Hey guys,
When I bought my 94 gt it had shorty headers on it with the smog port plugged with a bolt but I noticed today of a strange bypass setup that the previous owner did. He connected the bottom of the EGR Valve directly to the smog crossover valve thing that would normally go to the exhaust manifold. Is this a problem or is this okay? Looks like he used a big fuel line hose to connect the egr valve to the smog crossover pipe. So basically on the Smog Crossover pipe, one end is correct and bolts to the head and on the other end it goes to the bottom of the EGR valve by a fuel/vacuum hose connection. |
Anybody?
1995 Mustang GT
The 94-95 had the incoming exhaust coming up from around the #3 cylinder to the EGR. That was how they did it those 2 years.
98 Cobra
take a picture and post it if u can, it sounds like it would be ok
Okay here is a picture. As you can see, the vacuum hose used is also kinked at the EGR Valve exit and Smog Crossover exit.
That's a noble attempt, but I don't think it's actually capable of doing anything.
The pipe coming from the back of the heads has a check valve on the end of it, ensuring that exhaust can't come out of it, only air can go IN to it. Assuming that your EGR is hooked up and the valve can open, it will just be drawing against the check valve. Essentially, that hose is doing nothing. |
Threads Similar to: Strange Smog Crossover pipe to EGR valve setup
| AFR Head/rear crossover pipe | 88Saleen | 5.0 Mustangs | 7 | April 13th, 2011 03:37 PM |
| No crossover pipe in mid?? | 06GTMustang89 | 2005 - 2010 | 3 | January 29th, 2008 05:23 PM |
| crossover pipe | laserstang2 | General Tech | 4 | February 19th, 2007 02:59 AM |
| Crossover pipe | GreenFaleen | V6 Mustangs | 5 | December 1st, 2006 07:18 PM |
