5.0 EFI to carb swap questions
LinkBack (2) Thread Tools
Old June 14th, 2011, 02:39 AM   2 links from elsewhere to this Post. Click to view. #1
Cas9889 is on a distinguished road
Question
Ok so here's the deal. I recently picked up an 88 notch with an EFI set up on it that I didn't want. I took it off and traded it flat out for an almost complete Carb set up (holly carb, edelbrock intake, edelbrock fuel pump, FPR, 85 distributor, and 85 throttle cable). I have already taken out all of the EFI harness and there are a few wiring, vacuum line, and other misc. questions I have.
****I have searched for days and cannot find answers to these questions!!****
1. On the side of the EFI under-hood fuse box connected to the EFI harness there was a positive terminal that a bunch of wires ran to that are still connected to the chassis harness. Where do I connect these? I do not have a remote starter solenoid do I need one?
2. Can I use the Stock EFI hard fuel lines? or should I run new ones?
3. I have an 83 gas tank laying around that I need to sump. Can I use an 81-84 fuel sending unit and still have my gas gauge work?
4. what vacuum lines will i need to run? i know one to the booster and one to the vacuum advance on the distributor any others?
Thanks for the help.
Old June 14th, 2011, 06:49 AM   #2
come on people i know there are some of you who have done this please share your knowledge
Old June 15th, 2011, 11:17 PM   #3
ok so i went out and started playing with wires the ignition switch wire to engage the starter is on one of the two plugs by the brake booster it is white with a pink stripe still need more help on where more wires go
Old June 15th, 2011, 11:38 PM   #4
Proud American
MustangMatt96GT's Avatar
Personally I don't know what your talking about when you say all the positive wires.... picture would help
But I would run my own lines personally, your gonna need to run a different regulartor and are going to need a return to keep it streetable and reliable. Dead head systems love taking a crap quick. Using the older tank and sumping it would work, or just using your existing tank and sumping it would work too... I would use what you have and then you can keep the fuel gauge working properly....
Your gonna need a vacuum line from the carb to the brake booster and to the distributer and should be set.
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old June 16th, 2011, 02:29 AM   #5
Thank you sir. I figured out the positive wires issue but now I need to figure out which wires are for the oil pressure sending unit, temp sensor, and fuel pump since the relay is now gone. As well as how to wire my alternator up as for running a return line will using one of the stock hard line be okay to use? I am switching to -8 lines to the pump FPR and carb. Since your the only one who could help or try to help I have a Mallory Hyfire IVc im going to use but I don't have the Duraspark ignition set up so i do not know where to run the red wire in figure 9 in the book found here.
http://www.jegs.com/InstallationInst...50/650-697.pdf
Old June 16th, 2011, 08:02 AM   #6
FastStang91Lx's Avatar
1991 Mustang LX 5.0
Mustang FAQ - Wiring, Engine, Air Bag, ABS Tech Home That should make your life easier
Old June 22nd, 2011, 03:33 AM   #7
forgot to check back on this after i posted but mainly the thing i need now is a wiring diagram for the black and grey plugs by the master cylinder so i can run the wires i need to run and ignore the ones i dont need to worry about
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/222342-5-0-efi-carb-swap-questions.html
Thread 351W EFI swap to Carb? | FSB Forums | Page 2 | BoardReader This thread Refback May 15th, 2012 08:06 PM
Thread 5.0 EFI to carb swap questions | Forums at Modded Mustangs | BoardReader This thread Refback December 17th, 2011 10:24 PM
Threads Similar to: 5.0 EFI to carb swap questions
2.3 efi to 5.0 carb swap gomerandreas 5.0 Mustangs 1 May 9th, 2011 08:27 AM
95 carb swap ggreene 94-95 1 December 27th, 2010 10:01 PM
carb swap 90mustang50 5.0 Mustangs 5 June 22nd, 2010 02:59 PM
FI to carb swap on 5.0L H.O. TN.Frank 5.0 Mustangs 3 April 4th, 2009 10:48 AM
EFI to Carb swap? JONJON 5.0 Mustangs 3 September 22nd, 2007 05:54 PM
