91 GT 90 LX 5.0
Need Help!! P/S bolt!
Alright, well i went to install my p/s relocation kit and im basically one bolt away form being able to put everything back together. My problem is that i cannot get the power steering pump off the one the one bolt because it is too long. And the bolt is seized, my vice grips are just slipping idk what else to do!! Im so close but this is holding me up any help would be greatly appreciated!!!
Thanks
1991 GT- All Stock 1990 LX 5.0- CAI, Shorty headers, flowmaster, Tubular Upper and Lower Control arms, Tokico HP series, Eibach Springs |
89 GT
Did you put some heat to it?
91 GT 90 LX 5.0
well, i finally was able to get it off, i just couldnt get the vice grips tight enough before but..... when i went to remove the smog pump the bolt of the bottom broke off so now im stuck, im just going to run and get the belt and just leave the pump on there till i can think of a way to remove it
91 GT 90 LX 5.0
does any one have any ideas???
1991 GT- All Stock 1990 LX 5.0- CAI, Shorty headers, flowmaster, Tubular Upper and Lower Control arms, Tokico HP series, Eibach Springs Last edited by Dap1991; June 15th, 2011 at 01:03 AM. |
91 GT 90 LX 5.0
bump
1991 Mustang LX 5.0
BFH
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
89 GT
Kinda lost on what broke. The head on the bottom bolt? Got a picture?
91 GT 90 LX 5.0
ahhh no pic, i can try sometime( still seems like i daunting task to me lol im still a noob) but.... the smog pump is held on by 2 bolts one at the top and one on the bottom. I removed the bottom bolt, but when i went to remove the top bolt the head of the bolt twisted off so im left with the remainder of the bolt in the smog pump and still threaded into the bracket, hopefully that is a better explanation( after reading my other post i was even confused lol sorry) any ways, i was just seeing if any of you guys had any ideas on how to remove the rest of the bolt or how to remove the pump.
My only idea is to basically remove the enitire accesory bracket that the smog pump is attatched to and take it out the car and just cut if off since i have no plans to reuse the smog pump.... but that seems like alot of work and now im afraid ill break more bolts and.... im not even sure if its worth the trouble
89 GT
Not sure how much room you're working with, don't think I've ever even had a fox with a smog pump still on it. But you can either drill it out or heat it up and use a screw extractor. If it mounts to a removable plate and space is tight to do either of the two I mentioned, pulling the mounting plate might be the best way. Would that be the plate that also holds the alternator on? If so, it's pretty easy to get off. Just make sure you soak the bolts in penetrating fluid for a few hours first if they're breaking easily. If one feels like it's gonna snap the head off, hit it with the propane and get it hot.
91 GT 90 LX 5.0
ya the plate is the same one with the alternator, maybe some time this week ill try it out, i mainly just want to get it off so it looks a little cleaner
1991 Mustang LX 5.0
I'm not sure I'd touch anything else if I were you. You break everything, lolololololol
91 GT 90 LX 5.0
lol tell me about it, haha after 5 trips to autozone i finally found the right belt size so i got it running again so i think i might just be happy with what i have for now
1991 Mustang LX 5.0
Been there... Except I bought a handful of belts and returned the ones that didn't work. And I actually break about everything I touch, lulz.
91 GT 90 LX 5.0
lol i did some searching on the forum like a good boy and found a nice diagram for belt sizes and routing methods, well my dumb ass didnt follow the routing method for the first 4 belts and when i finally did i ended up with the belt that i started with lololol
1991 Mustang LX 5.0
Hahahaha.... Yeah, there's two common ways to route the belt depending what you are running for accessories. Two WAY different belt lengths
1991 Ford Mustang GT
if you have to take the accessory bracket off, its not a big deal, its held on by 3-4 bolts, you may have to remove the intentioner to get to one of them.....
The bolt that got stuck on the power steering, was it the long stud that screws into the cylinder head, if so you remove that by putting two nuts on it, then tighten them up and then just unscrew it, the second nut becomes a jam nut
91 GT 90 LX 5.0
i tried the 2 nut method and when i would do it they would both just unscrew each other, i was probably doing it wrong tho, was i supposed to tighten them all the way up the the p/s? i just kinda did it half way through the threads..... any way we ended up getting them off, I just couldnt get the vice grips tight enough but my dad was able to
i had my power steering pump off, with just the stud sticking out......Ya i just put two nuts on, and off it came.....and mine were in the middle of the threads.
You could have tried 3 nuts Also putting a little heat on the cylinder head may have helped, not to much though,(unless there aluminum, then i would not add any heat) and penetration oil, helps. Im lucky, California cars don't usually have the same issues as other states do
91 GT 90 LX 5.0
ya my car is a rusted peice of shit(but i love her) so every thing is corroded and stuff making everything alot harder and prone to snapping, like honestly when i pulled the carpet to do some "minor" patching i felt sick when i saw that my feet were being held up by the carpet and the more i dug in the rustier it got. But it runs like a champ and is fun as hell, looking back i just was to excited to get a 5spd and didnt look hard enough but now i know
1991 Mustang LX 5.0
Me and my friends learned a long time ago to bring a second set of eyes. We've had Mustangs for more than 13 years each, but when it's YOU buying the car, you miss so much cuz you just want to see all the positives. When I went to look at my car, I was by myself, but I had my buddy on the phone with me. They 'remind' you of things to check.
And for the two nut method, you have to tighten the nuts against one another really tight. They can be anywhere along the length of the threads. You loosen the one while tightening the other 'into' each other. Then you put your wrench on the inside one (the one closest to the part that you are trying to remove it out of) and unscrew it.
Threads Similar to: Need Help!! P/S bolt!
| looking for bolt ons!! | wxexs92 | 94-95 | 1 | April 27th, 2011 05:02 PM |
| Striped Pan Bolt hole And Exhaust manifold bolt hole what to do? | TX77 | 99-04 | 1 | November 29th, 2010 11:36 PM |
| Bolt on GT vs Bolt on WS-6 with video | 00gtCoolGuy | Drag | 4 | July 20th, 2009 10:10 AM |
| HELP! SOHC 6 bolt crank/ cobra 8 bolt crank interchangability? | the1968jeepthing | 99-04 | 2 | September 29th, 2008 11:39 PM |
