#21 |
1969 Mustang Mach 1
6.824@101.61
5-10 is defiantly pushing the limit though. 5 is no good. 10 is pushing it. 8 per 1000 RPMs is minimum. 15-20 at idle, like he mentioned, is no worries, and normal for something with a lot of miles.
./___ _ ____ ___ \. ( ]]] _ _ O _ _ [[[ ) \_ o _ _____ _ o _/ |___| ......... |___| http://www.youtube.com/watch?v=HyYU3...e_gdata_player |
#22 |
My friend told mr that it's so low because of the oil line it copper and super thin I picked up a new gauge and a steel braided line so hopefully it reads better
#23 |
Sorry if I miss letters iPhone FTL
#24 |
1993 lx 351 coupe
![]() iTrader: 1 reviews
meaning an older 351 block can hold more power than other blocks, I didn't mean that a certain year 351 made more power just because of what the year the block is
![]() Killer Performance |
#25 | |
1993 5.ohhhh
12.97 @140mph
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
#26 | |
Proud American
#27 |
Thanks for makingthat clear I'm installing the new line and gauge today along with the msd..... Btw your avatar (or pic below your name) amazing I had the words "don't tread on me" on my old car no one in Miami knows what I ment lol
#28 |
1993 lx 351 coupe
ok well i guess what a lot of ford techs have told me was wrong. Forget everything I've told you and listen to everyone else. I know nothing i just like making stuff as I go.
#29 |
1993 5.ohhhh
12.97 @140mph
Your misinforming people. No one cares what a ford tech says. 351's havent been in any ford in years dude.
#30 |
1993 lx 351 coupe
ok then 351 hasn't been used in years......so whats your point, neither has a 302,289, 352, 351c, i can go on and on...you win I'm done. apperently my years of building cars was just a bad dream..lol,
#31 |
1991 Mustang LX 5.0
Ford Tech FTMFW.... bwahahahahahaha. Most mechanics just know how to take bolts out, remove part, put new part in, reinstall bolts. Takes a good one to actually diagnosis things... especially on older cars like ours. My buddy has a 13,000 dollar scan tool to diagnosis most things for him, but I've seen him be wrong on a car that he couldn't hook that up to, and have to return parts lololololololololol. He owns his own successful business too, so it's not like he's just a chump either. He always tells me Fords are stupid. Since he owns his own business of repairing all makes and models except diesel's, he MUST be right....... right????
To the OP: You usually can't go wrong when going with the majority rule concept.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
#32 |
1969 Mustang Mach 1
6.824@101.61
351C's have been known to have some oiling issues. Maybe the tech is confused.
#33 |
well is it just the 351 or all ford small blocks?
#34 |
89 GT
I've never heard of this oiling issue either. Unless they're referring to the drainback system. Using a high volume pump can starve a SBF at higher RPM's because it will pump more oil into the top end than the drainback system can return back to the crankcase and you can starve the bottom end. But the easy fix for that is to not use a high volume oil pump.
Like said, 5 psi at idle is a bit lower than i would be comfortable with. I wouldn't expect that engine to last a whole long time. Seen guys run for a couple years on idle PSI that low though, but I would say you've got some main or rod bearings that need some attention. As long as that line isn't clogged, it's probably pretty accurate. I've used nylon line in the past that's pretty thin and it didn't change readings. |
#35 |
alright thanks guys im working on it lol
#36 |
1989 Mustang GT
car looks great. That thing is pretty slammed haha nice
#37 |
Yea love the ride height it's amazing thanks lol
Threads Similar to: my coupe build
| My 65 coupe build | slickrick65 | Classic Mustangs | 42 | March 2nd, 2012 03:33 PM |
| 66 Coupe (Re)Build Thread...Finally!! | Blown284 | Classic Mustangs | 9 | March 1st, 2011 02:50 PM |
| possible 91 coupe build | tweeters97 | 4V / SVT | 5 | August 9th, 2010 01:01 AM |
| 1969 Coupe Build | jfritts | Classic Mustangs | 9 | May 1st, 2010 07:35 PM |
