>>>>>>>Alarm System<<<<<
Old May 11th, 2007, 06:53 PM   #1
Flomaster_Knockoff is on a distinguished road
>>>>>>>Alarm System<<<<<
I have a 94 GT, it came with a stock alarm system that says (Ford Security System). the keychain control has 2 buttons "arm" n "disarm" it also has the words "Code/Alarm" on it. also, FCC: GOH-MM6-101890 DOC: 1409 K791
I dont know what all this shit means, but the alarm system seems to "arm" itself when i exit the vehicle. it also goes off all the time, even when nothing is around. I adjusted the sensitivity settings and it dont make a difference. I called code alarm and they need a model number? but i dont have one.
Anyone have this piece of shit alarm system? maybe its not a piece of shit, but my system is.
not really a strait foward kinda question but i was just wondering what you guys think about this or your expierences
Old May 13th, 2007, 07:56 PM   #2
gicantor2's Avatar
gicantor2 is on a distinguished road
Send a message via MSN to gicantor2
check your pin switches(hood,trunk,doors) for a loose connection. It might be triggering the alarm.
Old May 14th, 2007, 12:28 AM   #3
fogged306's Avatar
89 GT
Those alarms are garbage, they are aftermarket by code alarm as you already know. If you want to actually fix it you have to do process of elimination. First disconnect the shock sensor and arm it, see if it goes off. If it does then proceed to what gicantor2 said, do your dome lights work and if so do they come on with the doors closed. Other than that it may have a current sensing feature that may have been turned on or its just a bad brain. In all honesty those are such poor units that I always just replace them with something current.
If you need the model number, check the alarm brain, usually under the dash somewhere it will be a black box and have the blue oval on it.
Threads Similar to: >>>>>>>Alarm System<<<<<
Traction Control System (TCS) and Anti-Lock Braking System WAR-PARTY 99-04 14 May 1st, 2011 03:17 PM
Traction Control System (TCS) and Anti-Lock Braking System WAR-PARTY 99-04 11 June 18th, 2007 08:56 PM
Alarm system help please Onemanzu Audio/Video 7 March 27th, 2007 08:32 AM
Alarm system for convertible j3susfr3ak 2005 - 2010 3 February 19th, 2007 12:03 AM
new alarm system WAVEBYE The Clubhouse 27 December 23rd, 2006 08:36 AM
