Temp position when cold?
Old June 15th, 2011, 09:09 PM   #1
94FiveOVurt is on a distinguished road
I just picked up a 1994 Mustang GT that has aftermarket white face gauges on it but I think the previous owner put the needle for the water temp gauge back on incorrectly. From a cold start (car has been sitting for about 8hours or so) the temp starts out at the N or the word NORMAL.
I need to take the gauge cluster out and reposition the needle but I'm unsure where it should be from a cold start.
Could you guys let me know what yours read from a absolute cold start. I'm thinking probably right on the C (Cold) black line but thought it may even be before that.
Thanks
Old June 15th, 2011, 09:11 PM   #2
FastStang91Lx's Avatar
1991 Mustang LX 5.0
You are better off getting it to a known running temperature (via an aftermarket temp gauge) and resetting or just remembering where that temp is. Then you'll always know you'll be fine at that point.
Old June 16th, 2011, 01:47 PM   #3
Yeah I plan on getting an aftermarket gauge but want my factory gauge to sit where it supposed to as it's bugging me. Where does this needle sit when cold?
Old June 18th, 2011, 09:58 AM   #4
FIXED!!!
FYI- if you try to position the need back a bit it will still default back to what it was when the ignition is turned on so moving it will do nothing.
My problem was that the needle was not on the cluster all the way so the temp gauge would just skyrocket to the right after about 5 minutes of running. I pressed it it a bit more securely to the cluster and this morning it read C COLD when I started it and on the highway it was reading around the M in Normal instead of H (Hot).
Threads Similar to: Temp position when cold?
Help, What does your water temp gauge show when COLD? 94FiveOVurt General Tech 4 June 23rd, 2011 01:22 AM
Temp sensor and Temp switch issue tc3k101 96-98 2 March 7th, 2011 10:16 PM
Help with Cam Position CEL raetza 2005 - 2010 0 November 7th, 2010 08:30 PM
engine temp and oil temp off Reset? warrior86 V6 Mustangs 3 November 29th, 2008 01:48 PM
maf position Fastpitchdad 5.0 Mustangs 3 June 10th, 2007 09:56 AM
