Rpms raise when clutch is engaged
Old June 18th, 2011, 11:41 AM   #1
428CJ's Avatar
428CJ is on a distinguished road
Once my pos, 1988 Mustang GT, gets warmed up, I've noticed that whenever I engage the clutch to shift the rpms raise 500, and then lower after a couple seconds. It also wants to idle at 1300 rpms once it warms up, rather than the 800 when its cold. Also, I changed the oil with 10w30 synthetic and now the car ticks after 2300 rpms. Anyone have any suggestions to fix my pos' problems.
Just replaced:
ECT, ACT, IAC
cap, rotor, wires,
and the O2 sensors
1988 Mustang: 5 speed, hurst shifter, plenty slow.
Old June 18th, 2011, 12:02 PM   #2
94FiveOVurt is on a distinguished road
I have the same issues on my 94 5.0
I cleaned my IAC, Throttle Body, MAF, IAT. RPM will also hang at around 2K with clutch in or out until I completely come to a stop then it will come down to about 1k.
From the research i've done, its either a vacuum leak or TPS needs reset to spec via Base Idle Reset procedure.
Old June 18th, 2011, 12:22 PM   #3
428CJ's Avatar
Ya, when i let off it stays at the same rpm for like 5 seconds then lowers.
Old June 18th, 2011, 12:28 PM   #4
79fox's Avatar
1979 5.0 notchback
79fox is on a distinguished road
could your throttle be sticking?
Old June 18th, 2011, 03:06 PM   #5
428CJ's Avatar
I doubt that my throttle is sticking because it works perfectly fine when the car is cold. The issues only occur once the car is warmed up.
Old June 18th, 2011, 04:03 PM   #6
PsyAbe's Avatar
'92 LX
PsyAbe is on a distinguished road
Send a message via AIM to PsyAbe
Eliminate all vacuum leak possibilities by checking the vacuum lines and all things related. Here's a diagram to help you out, make sure you've unplugged MAF or equivalent to let the engine run on default values before spraying.
Old June 19th, 2011, 11:06 PM   #7
95tbirdv8's Avatar
1990 mustang gt
95tbirdv8 is on a distinguished road
sounds like a vacuum leak to me too. i had the same problem and i couldnt figure it out. one day for some reason i reached behind the intake and the vacuum line was unplugged from the pcv valve.
Burning Rubber in the 5.0
http://www.youtube.com/watch?v=mKGSmRkKQcM95
95 mark8 lsc 95 tbird v8 90 mustang gt 07 silverado v8 08 yamaha r6
to be continued........
foxbodyperformance.com is the way to go
Threads Similar to: Rpms raise when clutch is engaged
Got engaged! M.P. Cobra Fan The Clubhouse 114 December 23rd, 2010 01:02 AM
Car Shuts off When clutch is Engaged centipede3001 5.0 Mustangs 12 December 4th, 2010 02:01 PM
Im engaged! haha Dolbs4082 The Clubhouse 46 May 26th, 2010 02:05 PM
So i'm engaged now... Fox2102 The Clubhouse 37 September 6th, 2009 03:24 AM
96 cobra clutch slips at low rpms in 5th 96whitesvtcobra 4V / SVT 24 July 10th, 2009 10:57 AM
