89 Mustang LX Hatch
Brake Fluid?
How often do you guys generally have to fill your brake fluid? I'm filling my reservoir once a week and that seems excessive. I looked at the front and rear brakes and everything is dry. I checked around the master cylinder and it's dry as well. I didn't go and follow every line to the brakes yet. Is this a common problem with these cars? If so, is there a particular trouble spot?
I would check the wheel cylinders, when you pull the drums off look inside the rubber boots and see if there is any brake fluid in them. Another possible place for brake fluid leakage that can't be seen is into the booster to check that though you would have to pull the master cylinder off the booster and look for signs of leakage.
315's Crew Black and White Crew Crew Member #2
89 Mustang LX Hatch
Thanks for the info, I'll check those things out.
Never. It should only get a little low as your brakes wear out but will go right back to the original level with new pads/shoes. ANY fluid loss is a problem that needs to be looked at.
89 Mustang LX Hatch
The pads and shoes are new from the end of last season and this just started like 3 weeks ago. It's gonna have to wait until next weekend. I need to check the drums and booster out because there are no obvious leaks under the car.
1991 Mustang LX 5.0
Why you make your thread over here? Tsk Tsk!
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
89 Mustang LX Hatch
That's a good point faststang. Lol
Threads Similar to: Brake Fluid?
| what brake fluid and power steering fluid? | V8POWA! | 96-98 | 7 | May 2nd, 2011 01:32 PM |
| Brake Fluid | sikedsyko | General Tech | 2 | February 24th, 2010 05:01 AM |
| Brake Fluid | sikedsyko | V6 Mustangs | 8 | January 22nd, 2010 02:24 PM |
| brake fluid | Racerchik02 | V6 Mustangs | 10 | September 14th, 2007 06:05 PM |
| how much brake fluid? | juan310 | V6 Mustangs | 22 | July 18th, 2007 10:39 AM |
