LinkBack (10) | Thread Tools |
#1
Vortech Supercharger rebuild
Vortech makes some of the best Superchargers on the planet but as with all parts that need a rebuild sooner or later. Here is some info on whats required.
This is what you need: 2 Nachi ball bearings nac-6003 (must be speed rated) 2 SKF Ball Bearings 6205/C31 Chicago rawhide seal SC/R-62481 Transcom seal TCM-25x40x7tc1 Chicago Rawhide Speedi sleeve C/R-99062 That is everything needed for replacing the bearings, seals, etc. Disassembling it is real easy...just take off the 8 bolts holding the front cover on, take off the impellar nut (i think i remember it being left hand thread), take off the compressor case and impellar and mark it so you can have it clocked right for reassembly. As for the rest, it is obvious how it comes off and you will have to have the old bearings pressed off and the new ones pressed back on. The toughest part is getting out the main shaft but with a small piece of threaded rod the size of the pulley bolt and a few quick blows from a hammer and it's out...anyways, it is really simple to do and is EXTREMELY cheap compared to Vortechs price to rebuild so there ya go. That is the very brief version of how to take it apart, there is a little more fine detail to it but you'll see once you start. just be careful with everything. this is replacing all the parts that vortech calls a "minor repair" at $395. all these parts cost WELL UNDER $50 if i remember correctly...maybe closer to $25 |
THESE parts just normal off the shelve parts and cost is like 75.00. vortech is making a killing after I see how my rebuild goes I may start to do these for about half of what vortech does them
wow it seems crazy that anyone would pay that much to hvae that done when its that easy! someone could make a good living rebuilding peoples s/c for half that.. do it up vfast
![]() A U D I //S4 2000 6MT/TT/AWD Stage 3 in the works.. 460+ awhp 455 lb/ft torque, 500+ awhp on race gas
an to think they will have a wait list next month
Look Ma! My First Post!
Where to find bearings for vortex
This is an old thread I found using a search engine, can you tell me where you found these bearings, I have search the part # and came up with nothing. I just need to know where I can purchase on-line or phone number perhaps.
Any help is greatly appreciated Steve |
ya i have vortech v1 supercharger needs rebuild can you help me out with parts where i can get them thank you so much formulafb2000@yahoo.com
TTT from the dead.
I also have V9 vortech charger. Due to hydrolocking my motor, water got into the charger also. I drained all water out nextday, and its been 2weeks now the charger is sitting on my garage. I see some corrosion inside the charger. I called vortech for repair/rebuild. They qouted me $700~$$. What can I do?? Can I just relube everything and use it?? charger only has about 7k miles. |
have vortech rebuild it... it'll be warrantied that way
They didnt say my charger is going to be warrantied..
Charger is used a year and 2months now. |
Does it still have the warranty tag on the head unit?? if it's been removed then they won't touch it without charging you a full rebuild cost. If you do have them rebuild it, they will warranty it but don't remove the tag or else again no warranty
I will make sure check that tag. I remember I saw a blue tag on the charger with all the numbers. Im going to double check that.
Threads Similar to: Vortech Supercharger rebuild
| Vortech supercharger | scubasteve041186 | General Tech | 23 | August 25th, 2007 06:43 PM |
| What oil to run on a vortech supercharger?? | bossman2kgt | 99-04 | 7 | June 24th, 2007 05:44 PM |
| supercharger rebuild... | Flavian | 5.0 Mustangs | 2 | March 30th, 2007 10:18 AM |
| Vortech Supercharger | The eaglenator | General Tech | 7 | September 30th, 2006 01:48 PM |
