how to remove harmonic balancer
LinkBack (1) Thread Tools
Old June 20th, 2011, 01:28 PM   1 links from elsewhere to this Post. Click to view. #1
94 mustang,88 mustang
n/a
black05gt is on a distinguished road
How can I remove my balancer? I'm gonna rent the puller tool from autozone but how do I remove the middle bolt? Every time I try to take it off the engine turns
2011 Malibu LTZ (Daily driver)
94 Mustang GT (Weekend toy)
88 Mustang GT (Track car)
Old June 20th, 2011, 02:02 PM   #2
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
Did you put the car in gear?
./___ _ ____ ___ \.
( ]]] _ _ O _ _ [[[ )
\_ o _ _____ _ o _/
|___| ......... |___|
Old June 20th, 2011, 03:34 PM   #3
GMcanblowmyFORD's Avatar
1993 stang GT
NA
GMcanblowmyFORD is on a distinguished road
mine was on stand when i took it off, i stabbed a screw driver in, messed one up in the process but it worked n pounded off with hammer it was junk so i didnt care..
ill still smoke honda's with no engine in my stang!
You dig the trench I lay the pipe!
Old June 20th, 2011, 04:28 PM   #4
fogged306's Avatar
89 GT
Impact gun.
Old June 20th, 2011, 05:10 PM   #5
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
Originally Posted by fogged306 View Post
Impact gun.
I was going to mention that, but I didn't know if you could get one in there. There's no way in hell you can hit mine with an impact, with the engine in the car.
./___ _ ____ ___ \.
\_ o _ _____ _ o _/
Old June 20th, 2011, 09:51 PM   #6
1991 Mustang GT
S my 5.0 is on a distinguished road
I had my car in 5th so the engine doesn't turn =]
Old June 20th, 2011, 11:16 PM   #7
fogged306's Avatar
89 GT
This is true. I'm too used to pulling the engine, lol. You would have to pull the radiator to do an impact. If it's stick, in gear with a breaker bar will be a lot quicker.
Old June 21st, 2011, 12:03 AM   #8
Alan03gt is on a distinguished road
put it in gear, pull the e brake, use a breaker bar, ... or pull the rad. and impact it.
REMEMBER to pull the washer out, once... my washer was stuck in with sealant? and i forgot it was there...you cant pull a balancer when your pushing on the washer instead of the crank!!!!! duhhh
Old June 21st, 2011, 02:39 PM   #9
n/a
When I put it in reverse it holds still but its so tight that I'm scared of breaking something while taking it off. Will everything hold fine or can something break.
Old June 21st, 2011, 04:10 PM   #10
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
No way. Only thing that would break is the bolt, and that's a big bitch. Doubtful it'll break.
./___ _ ____ ___ \.
\_ o _ _____ _ o _/
Old June 21st, 2011, 04:30 PM   #11
The Big Spoon
jessemachone's Avatar
88 5.0 5 Speed Notch <><
never fast enough
jessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of light
I didn't need a puller to pull mine nor did i need anything special to install it. It just went right on.... maybe i did tap it a few times or something but I remember being baffled by the fact that I didn't need to use a puller to get it off. Car runs fine with no vibes. Weird.
Black Stang Crew
Originally Posted by 302Army187 View Post
old 5.0's are like a box of chocolates.......... never know what your gonna get
Old June 21st, 2011, 05:53 PM   #12
fogged306's Avatar
89 GT
Damn.. Your balancer's been around the block a few times I guess.
Old June 22nd, 2011, 03:03 AM   #13
1988 convertible's Avatar
1988
1988 convertible is on a distinguished road
Send a message via Yahoo to 1988 convertible
you can get a good cheap re-chargeable impact wrench off ebay for next to nothing... i had the same issue... i got one and its the best buy i've had so far!
Old June 22nd, 2011, 06:06 AM   #14
The Big Spoon
never fast enough
Dewd, the new one went on just as easy. I replaced it because the rubber isolator failed and the balancer ring was wobbling.
Stock replacement from autozone - I needed one right then and there.
I still have the center of the old balancer. It makes for a great seal installation tool.
Black Stang Crew
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/223102-how-remove-harmonic-balancer.html
Thread how to remove harmonic balancer | Forums at Modded Mustangs | BoardReader This thread Refback April 12th, 2012 07:21 PM
Threads Similar to: how to remove harmonic balancer
harmonic balancer ?'s Sally845 5.0 Mustangs 10 February 26th, 2011 11:10 PM
harmonic balancer Stubs 2005 - 2010 13 October 18th, 2010 01:07 PM
Harmonic Balancer shurb125 5.0 Mustangs 14 December 3rd, 2007 01:01 PM
Harmonic Balancer dreamr 5.0 Mustangs 9 October 30th, 2007 08:54 PM
Harmonic Balancer shawn91stang 5.0 Mustangs 4 January 6th, 2007 12:24 AM
