1988 mustang 5.0
Please help temp issue
Hi people thanks in advance, I have a 88 mustang 5.0 302 all add ons listed here BBK cold air intake BBK equal length shorties BBK off road h pipe spin tech mufflers MSD cap rotor and wires and last a pro form 180-240 adjustable 2800 cfm electric fan. I had the stock 195 thermostat in it it was running at 200-225 I put in a 180 stat thinking it would open sooner and help cool down faster. Still was running hot I took stat out and still have issue. It has a new water pump and tried to new stats and burped the system also where not put in back words. Today was pretty warm around 86 deg. I seen temp today of 230 I need to get thus temp down any suggestions would be very helpful I would like to see 190-200 at all times. And second what is a too hot temp for a 302 with my mods and second running at 14* timing. Thanks for all help. No leaks of oil or coolant no blown head gaskets did a pressure test and blue chemical test kit and cap is working it is new also. I am running a after market oil pressure and water temp that is accurate temp reading.
1988 mustang 5.0
Please no one can help???? I really need advice on next step with this issue.
2000 GT 'vert
How is the radiator? Are the fans actually turning on?
Sent from my Nexus One using AutoGuide App |
1988 mustang 5.0
Yea the fan kicks on at 180 I have adjusted to make sure and it kicked on at 200 also but put back to 180 when gauge says 180 fan is turning on I have even turned on defroster to kick fan on before 180 and it didn't seem to help I wired it into the ac and as for the radiator it looks clean and I took off bottom hose put hose in radiator fill neck and it flowed threw the radiator really fast so didn't seemed clogged. Another question would 14* timing run a extra 20-30* degrees I know it runs hotter BUT that much?
1988 mustang 5.0
Did I post this wrong in wrong section or what I am new here read threw other post replied to help them out. No one seems to post here but one person is there no help?
Proud American
Sometimes you need to be patient... we have people with really good knowledge, but they are not on 100% of the time... Just like me school is out so im more, but recently my tranny has been in and out 3 times the last two weeks...
There isnt much it really can be. the radiator, the water pump, or a fan thaat is going the wrong way. you need to draw air through the radiator and then blow on the motor for an electric fan to work properly. Also if its getting warm, is that only on the highway, in town, only when idling?
93 5.0 lx
Some of the knowlegable veterans in this section got banned.. and sorry idk what it could be, maybe shitty fans
Heres an idea.. ban the ones that are most knowlegable and helpful in the 5.0 section...oh wait lmao |
1988 mustang 5.0
The fan is a pull not a push. I got it out of summit in the mustang fox body section it worked fine before now it is acting up. Is there a way that I don't know to test to a radiator ? Like I said I put water hose in top removed bottom hose and flushed if u want to call it and it seems to flow the water as fast as it was coming out the hose. And sorry I was seeing other post and they had 10-2@ post in Less then 30 mins and mine only had one that's all. but thanks for help btw.
1988 mustang 5.0
To answer that question about when it gets hot all the time no mater city freeway or stop it just runs hot. Today I drained the coolant system and flushed block and then radiator. I then put timing back to 10 degrees all tho it is not abouve 80 degrees when I drove it and I drove it like I stole to to see what happens it reached max of about 205 then shot down to 197-200 and stayed there no matter how I drove it I drove about 20 miles and I drove it hard freeway and city. So next question is could it be the radiator I started it watched the water level go down and watched the water flow pretty good throw radiator. But I want to run it at 14* timing it runs soo good set at 14. It's a big diff from 10 to 14. I can only assume it is the radiator but would like some more input first.
1990 5.0 LX SSP
High temps. seem to be common now days. There is another thread or two already on the 5.0 section. I've done everything under the sun to my 306 and I still feel it should run cooler. If I knew what to tell you I would.
Good luck.
1988 mustang 5.0
Thanks I just don't want to invest in a big radiator for it not to work maybe stay stock I know big radiators some times make over heating problems. My dad ran a big four core 1inch tubes on his 454 in a 87 1ton for pulling a trailer sand rail Two dirt bikes and two quads and it actually made it run hotter. He went back to stock and it ran perfect at 210 none stop. I know big radiators are for fast cool down track days but sometimes beside my dads I have herd others long driving they don't cool down fast enough so I don't know if I should stay stock or order a 2 row one inch tubes it's 89$ verses 200$. All I want is to run 190-200 ALL TIMES 210 MAX no matter ac on running hard climbing hills there a few big hills where I live that temp has seen 225 running up them I'm leaning to a bad radiator can really be any thing else?
#12 | |
2000 GT 'vert
1988 mustang 5.0
Awesome and thanks I am going to kragens when it cools down to get a new radiator that's the last option I know if that doesn't work I will be super stumped. I'm doubtful it is based on seeing it flow good when flushing it and after it ran it was low and the water was flowing nice on top so I don't know if middle or bottom is clogged but will let results be known.
2000 GT 'vert
On the way in to work this morning, 5am..
Temp 85: Coolant temp: 192 while moving 196 while at stops. IAT: 84 while moving, got up to 91 while stopped a long time. will update with the temps during my 113 degree commute home. |
1990 mustang gt
why dont you try putting on the clutch fan if you still have it and check the temps. maybe the fan isnt turning fast enough
Burning Rubber in the 5.0 http://www.youtube.com/watch?v=mKGSmRkKQcM95 95 mark8 lsc 95 tbird v8 90 mustang gt 07 silverado v8 08 yamaha r6 to be continued........ foxbodyperformance.com is the way to go |
1988 mustang 5.0
The clutch fans locked up and spins at all times and it was having a little issue of getting hot. That's why I went with the electric fan conversion to see if it would cool down better then the clutch fan and wanted to get rid of the clutch fan to go electric in the long run.
1990 mustang GT
you should try the original fan shroud on
Bored and Stroked 347 3.73 gears BBK Shorty headers BBK 255lph pump BBK intake Edelbrock performer II heads Ford 30lb injectors ![]() http://www.youtube.com/watch?v=I6TGUNjYuaE&NR=1 http://www.youtube.com/watch?v=3sFORkfhrY0 |
2000 GT 'vert
Any new news?
I also data logged on the way home... 113 degrees outside : While driving at 2k rpm, IAT read 118 and coolant held at 202. Cruising at 3400 rpm IAT 118, coolant 208. In traffic at long light, IAT 130 and coolant went as high as 220. Sent from my Nexus One using AutoGuide App |
1988 mustang 5.0
Thanx for that input I'm hitting 220 on freeway at 1800 rpms and seeing 235 max running up two hills to get home I have a new radiator I am gonna put it in the next few days when I have the time. Let you kow the results.
Threads Similar to: Please help temp issue
| Temp sensor and Temp switch issue | tc3k101 | 96-98 | 2 | March 7th, 2011 10:16 PM |
| electrical issue with temp gauge | banks90gt | 5.0 Mustangs | 3 | September 6th, 2010 02:57 PM |
| Temp gauge issue? | 06VistaBlueGT | 2005 - 2010 | 10 | June 17th, 2009 01:23 PM |
| Water Temp Guage issue | Jeepin ina 97xj | Audio/Video | 0 | April 9th, 2009 11:26 AM |
| temp. issue | j2000_guy | 5.0 Mustangs | 2 | July 25th, 2006 06:16 PM |
