smog,ac,p/s,removal
Old June 21st, 2011, 02:35 PM   #1
94 mustang,88 mustang
n/a
black05gt is on a distinguished road
smog,ac,p/s,removal
I already have a smog pump removal and I wanted to remove my a/c and power steering can I just remove them and get a shorter belt .
Thanks
2011 Malibu LTZ (Daily driver)
94 Mustang GT (Weekend toy)
88 Mustang GT (Track car)
Old June 21st, 2011, 10:19 PM   #2
79fox's Avatar
1979 5.0 notchback
79fox is on a distinguished road
are you gonna use the stock steering rack?
Old June 21st, 2011, 10:38 PM   #3
PhillyGT's Avatar
2001 Mustang GT
13.8@101.58mph!
PhillyGT is on a distinguished road
Why would you want to? Imo, its not worth the 2-3 hp gain.
Dropped on Eibachs,K&N FIPK,Mac-prochamber o/r,Flowmasters.Short throw,Heavy Right Foot Mod
Old June 22nd, 2011, 12:10 AM   #4
1992 Mustang Lx 5.0 347ci
11.8@115
SloMo is on a distinguished road
I thought the water pump had to spin a certain way, clockwise I think. I don't think you'd be able to route a belt to spin the pump that way without having a pulley on the driver side of the motor. I could be wrong though.
Slow Motion... Quick reving, High compression, Big Boy 347 stroker... STROKER MOTION...
Old June 22nd, 2011, 12:54 AM   #5
n/a
Yeah if I can use the stock steering rack
Old June 22nd, 2011, 02:05 AM   #6
1988 convertible's Avatar
1988
1988 convertible is on a distinguished road
Send a message via Yahoo to 1988 convertible
Yes you can as long as you get a P/S relocation bracket otherwise the belt wont clear the water pump pulley. the belt will travel in the same direction as before.
the way i see it is the less crap you have in there the less there is to fix when it goes wrong... also your losing a nice bit of weight and making the engine bay look cleaner...
just be prepapred to make some minor adjustments to the timing at the distributor.
good luck
Old June 22nd, 2011, 11:15 AM   #7
11.8@115
Why adjust the timing? Less drag on the motor so it would idle higher?
Old June 22nd, 2011, 09:34 PM   #8
n/a
Thanks 88 convertible where can I buy the bracket? And why would i have to change timing
Old June 23rd, 2011, 02:24 AM   #9
1988
*ding ding ding*
we have a winner
its not noticeable at first but if your climbing up a slope or hill you can hear it firing too late... its only a minor adjustment but it annoyed me when i removed the smog pump... now i've taken out the P/S and A/C im gonna have to do a minor adjustment once the motor is back together...
Old June 23rd, 2011, 02:28 AM   #10
1988
you should be able to get a bracket from any large motorfactor like latemodelrestoration or summit racing...
this is an example of what your looking for:
1985-93 Mustang 5.0L Ford Racing Air Conditioner (A/C Delete) Eliminator Bracket, M-8511-A50 at LRS - Same Day Shipping!
as i said above only a minor adjustment to your timing to advance but only if you notice it fires late...
Old June 23rd, 2011, 03:46 AM   #11
1988 Mustang 5.0 LX
12.48@118.27
ddarkslayer is on a distinguished road
Its counter clockwise
Old June 23rd, 2011, 08:45 AM   #12
11.8@115
Thank you, like I said I wasn't sure of the rotation.
Old June 23rd, 2011, 02:03 PM   #13
Dap1991's Avatar
91 GT 90 LX 5.0
Dap1991 is on a distinguished road
i removed my a/c and smog using the a/c delete bracket and if nothing else it makes the engine bay way cleaner
1991 GT- All Stock
1990 LX 5.0- CAI, Shorty headers, flowmaster, Tubular Upper and Lower Control arms, Tokico HP series, Eibach Springs
Old June 23rd, 2011, 03:05 PM   #14
11.8@115
I am planning to go to manual steering later on. My car is already a non A/C car from the factory...By all I've seen, I'll have to find an A/C bracket and install that and use an A/C delete pulley to keep the serpentine belt right?
Old June 23rd, 2011, 03:59 PM   #15
1988
if you go to march performance they produce a set of brackets that you can use... im doing the same thing changed to a manual rack as well and since i got a new waterpump only last year i dont wanna get a new one...
get an alternator bracket and the a/c delete plate which holds the belt tensioner giving you 4 pulleys in use keeping the stock rotation. crank,water,alt,tensioner
First image at the top of the page:
FORD SMALL BLOCK SERPENTINE BRACKETS
Old June 23rd, 2011, 04:19 PM   #16
11.8@115
By looking at those serpentine systems. They do not have the belt routed correctly. That makes me think the water pump will not operate properly.
Old June 23rd, 2011, 04:27 PM   #17
1988
it is the correct rotation just different areas of the pulleys are in contact with the belt.
if it seems confusing draw the location of each pulley on a piece of paper and then draw a line the belt follows around each one...
i would not be modifying my motor to take this set up if i didnt know it worked
have a little faith n trust me
Old June 23rd, 2011, 04:35 PM   #18
11.8@115
Lol, very well.
Old June 23rd, 2011, 09:18 PM   #19
kmedeiros88's Avatar
89 Mustang LX Hatch
kmedeiros88 is on a distinguished road
Yep the waterpump will still go in the right direction.
Threads Similar to: smog,ac,p/s,removal
smog pump removal question MustangShelly01 5.0 Mustangs 2 June 22nd, 2011 02:29 AM
Smog Pump Removal Question. femurphy77 5.0 Mustangs 3 April 6th, 2011 07:03 AM
smog kevin86freeman 99-04 8 August 18th, 2008 10:30 PM
94-95 GT Help Smog Removal ujslost 94-95 2 April 10th, 2008 09:10 PM
Smog Pump Pulley removal OTreborO General Tech 0 May 16th, 2006 05:08 PM
