possible numbers and reliability
Old June 21st, 2011, 05:21 PM   #1
mustang9450 is on a distinguished road
I am looking to put a superchager on my 94 mustang with a 5.0. it is alreadsy bored .30 over with dss forged pistons, afr 165 alum. heads, systemax upper and lower intake with spacer, full exhaust, msd box, tremec tranny, 373 gears, comp cam and roller rockers, ford racing crank, high volume oil pump with 9 qt pan, 30 lb injectors, 255 lph walbro fuel pump, 76mm c&l maf, 70mm throttle body, and a few other small things. It has a sct 4bank elim chip tuned and put down 306 rwhp and 320 torque.
I am wondering if anyone has every put the procharger d1 on a setup similar to this and what kind of number you made with about 10-12 psi. I also know my stock block wouldnt handle no more than 500 hp without splitting, so in your opinion is it even worth supercharging this setup or should i save up and work with something with a better block that can handle more power?
Old June 21st, 2011, 10:05 PM   #2
anyone have any estimates or feedback?
Old June 21st, 2011, 10:11 PM   #3
79fox's Avatar
1979 5.0 notchback
79fox is on a distinguished road
whats your goal with power?
Old June 21st, 2011, 11:55 PM   #4
well i was looking for 500 but i know thats pushing it with the stock 302 block from those years so i may keep it safe with like9-10lbs of boost and shoot for about 450rwhp
Old June 22nd, 2011, 08:02 PM   #5
TTT
Old June 22nd, 2011, 11:38 PM   #6
91cobra5.0's Avatar
98 Cobra
with that set up you will be able to make 500, its all gona be in the tune, i have a friend with the trick flow top end package and a s trim (vortech i think) and he made 436whp and its on a very conservative tune. i think hes pushing 8psi but im not 100%on that one
Old June 23rd, 2011, 01:19 AM   #7
yeah im sure i could make 500 but i know that will be pushing the blocks limits. did he keep his boost down for the same reason? or what did his tuner do to be conservative?
Threads Similar to: possible numbers and reliability
So much for honda reliability... 98FireyGT! The Clubhouse 15 April 9th, 2011 10:24 PM
k member reliability?? harley1500man 99-04 12 January 12th, 2011 08:36 PM
Supercharge or cam reliability Givethecash Modular Mustangs 3 April 9th, 2010 12:40 PM
Reliability of a 5.0 stroker blackstang2004 99-04 18 August 9th, 2008 12:19 PM
Website reliability whtpny Vendors 6 February 16th, 2007 04:32 PM
