Getting some hesitation..?
Old June 22nd, 2011, 11:04 PM   #1
1989 Mustang GT
N/A
89FoxbodyGT is on a distinguished road
I'm new to the board, so whats up everyone?
Anyway. My 89 5.0, I've only had it for a couple months now, but here within the last few days I've been getting some hesitation when I accelerate, I figured it was some water in the fuel lines so I put a little bit of rubbing alcohol in my gas tank.
It stopped for a couple days, but now it came back.
So I'm assuming that it isn't water in the fuel lines because I haven't filled up since then, so could it be the spark plugs?
I don't think the Intake timing is off. What else could it be that's causing this?
Old June 22nd, 2011, 11:19 PM   #2
00MustangGtPremium's Avatar
2000 Mustang Gt
no clue
00MustangGtPremium is on a distinguished road
It could be many things. What exactly do u mean by hesitation and when exactly does it happen? ( like as soon as u hit the gas or while accelerating)
Old June 22nd, 2011, 11:24 PM   #3
1989 Mustang GT
N/A
It happens as I'm accelerating, like I can feel it kind of cut out as I'm going down the road, not like it should. Not full on lose power, but like it kind of jumps a little.
Old June 23rd, 2011, 02:33 AM   #4
1988 convertible's Avatar
1988
1988 convertible is on a distinguished road
Send a message via Yahoo to 1988 convertible
if you let the car warm up it wouldnt be the plugs as that would only happen with old plugs on a cold start...
is that gradual acceleration from what your experiencing the issue or full on throttle?
Old June 24th, 2011, 01:24 PM   #5
2000 Mustang Gt
no clue
It sounds like a dying battery, bad fuel pump, or dirty fuel injector ( Im not sure about the last one). Im leaning towards the battery.
Old June 24th, 2011, 01:53 PM   #6
PsyAbe's Avatar
'92 LX
PsyAbe is on a distinguished road
Send a message via AIM to PsyAbe
Perform some routine maintenance first. Also, there's a great chance you have to get your EGR valve replaced. A faulty one makes its presence most visible during acceleration and is known to cause jerks and hesitation when flooring the pedal. For good measure check your dizzy and its cap, that can also cause bad acceleration
Old June 24th, 2011, 04:10 PM   #7
1994 Mustang GT
ntilehman is on a distinguished road
i would go for plugs, wires, cap, coil, and fuel system. look at the fuel filter to see if it needs replacing. they can clog up. if none of it has been done in a while i would say go for it all. a lot of intermittent surging can be the ignition system.
Black 94 GT
Drag Springs 4:10 Gears Lakewood shocks/struts
Racestar wheels
White 96 Cobra
V-1 S trim 4:10 Gears
275/40-17 all around Basani Cat Back Exhaust
2001 DHG Bullitt
V-2 S trim 3.73 315/17 Rears Magnaflow Catback
Old June 24th, 2011, 07:23 PM   #8
flattusmaximus78's Avatar
1993 5.ohhhh
12.97 @140mph
Damn guys be real. Scan for codes first.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed
--Moates Quarter horse $225--
--Cobra intake $150--
--tremec 3550 bell and shifter $1100--
Old June 25th, 2011, 09:07 AM   #9
FastStang91Lx's Avatar
1991 Mustang LX 5.0
Sounds like another case of the blind leading the blind.
Old June 25th, 2011, 09:30 AM   #10
1993 5.ohhhh
12.97 @140mph
Thats how this section is these days. What a shame <3
Threads Similar to: Getting some hesitation..?
hesitation riddlee josh V6 Mustangs 8 April 19th, 2010 05:26 PM
Hesitation between 4-5k RPM... astras 5.0 Mustangs 6 March 10th, 2009 10:20 AM
Hesitation gotime89 5.0 Mustangs 11 October 12th, 2007 09:24 PM
hesitation? CBSTANG 99-04 5 July 26th, 2007 07:57 PM
Please Help! (Hesitation) das50cal 2005 - 2010 4 September 10th, 2006 09:44 PM
