1989 GT 'vert
rocker arm questions
Hey all, I have a set of trick flow 170's that need rocker arms. I know they're 7/16's stud mount, and I think 1.6 ratio are what I need? Can anyone give me some suggestions on which brands/sizes to look for, and anything else I would need to install them? Thanks for your time.
1989 GT 'vert
Can anyone tell me if they're using TF heads, and what rockers they're using on them?
1989 Black LX---Turbo
I have TW 170's on my 82 Capri. I am using 1.6 Harland Sharp with 3/8" stud, because my heads came with 3/8" studs. My son has TEA TW 185's on his Mustang and he is using Scorpion 1.6 with 7/16" studs. Both work great!!
89 LX Black, Boss 331, C4,T76BB, FAST EFI 82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc. 73 Dart Sport 340, 410ci Bracket Brawler 72 Demon 340 4-speed 1 of 1667 01 Ram Quad Cab 03 Grizzley 660 |
1989 GT 'vert
awesome! I just bought some off ebay last night. Im looking forward to getting this all put together. They came with the rockers and polylocks, there isnt anything else needed for the install is there?
TW also require a custom length pushrod, usually in the 6.70" range, but I have used 6.55" before also. Follow the instruction with the TW heads and it will explain how to check for proper length pushrods!
1989 GT 'vert
Thanks again for the info Horse! I heard there's some flooding going on up that way around the air force base. Is it affecting you?
#7 | |
89 LX Black, Boss 331, C4,T76BB, FAST EFI 82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc. 73 Dart Sport 340, 410ci Bracket Brawler 72 Demon 340 4-speed 1 of 1667 01 Ram Quad Cab 03 Grizzley 660 Last edited by horsepowerjunkie; June 25th, 2011 at 02:24 PM. |
1989 GT 'vert
GEEZ!!! I'm sorry to see that. I hope everyone got out ok. Prayers for a quick recovery as well.
#9 | |
#10 | ||
88Notch 10.59 @132 / 03 Mach 1 13.1 @104
^^Thats what I am using.. work fine...
Military Crew USMC
1969 Mustang Mach 1
6.824@101.61
You don't have to use Trick Flow rocker arms with TW heads. Most rocker arms will work. I use Comp Cam Ultra Golds on mine.
Make sure you measure for pushrod length. Nobody can tell you what size it will be, and if you don't have proper valvetrain geometry, it will cost you horsepower, and cause premature wear on your valvetrain components. Also, make sure you're using the right guideplates for TW heads.
./___ _ ____ ___ \. ( ]]] _ _ O _ _ [[[ ) \_ o _ _____ _ o _/ |___| ......... |___| http://www.youtube.com/watch?v=HyYU3...e_gdata_player |
Threads Similar to: rocker arm questions
| Roller Rocker Questions | Robert20 | 5.0 Mustangs | 3 | May 14th, 2011 02:21 PM |
| Rocker stripes on/off?! | MRKsD3 | Pictures | 36 | February 9th, 2011 02:38 PM |
| Rocker stud and other questions | 95Pony | 5.0 Mustangs | 5 | December 5th, 2010 09:55 AM |
| Rocker Arm help | ModularSteed | 96-98 | 0 | June 28th, 2009 08:08 PM |
| Rocker arm questions | Maxwell881 | 5.0 Mustangs | 2 | March 25th, 2007 07:24 AM |
