stock pullies vs. underdrives
I was wondering if i can use the lighter weight underdrive pullies with a supercharger system or do i have to go back to the stock pullies for it to work right?
1992 Mustang Lx 5.0 347ci
11.8@115
I don't see why it wouldn't work properly. The underdrive crank pulley may affect your boost level tho.
Slow Motion... Quick reving, High compression, Big Boy 347 stroker... STROKER MOTION... |
i had heard underdrive pullies slow everything down causing boost to drop
The underdrive crank pulley will lower your boost but you could use the other underdrive pulleys.
315's Crew Black and White Crew Crew Member #2
well if im not mistaken the only other pullies that come in an underdrive kit are the alt and waterpump right
1988 Mustang LX 5.0
I have heard of blowers causing lower quality aluminum underdrive pullies to distort due to more load.
Rust is lighter than metal......right. |
1990 mustang GT
ha sonataking05 to answer your sig no rust weighs the same unless some has been nocked off. wonder the same thing my self a few yours ago
Bored and Stroked 347 3.73 gears BBK Shorty headers BBK 255lph pump BBK intake Edelbrock performer II heads Ford 30lb injectors ![]() http://www.youtube.com/watch?v=I6TGUNjYuaE&NR=1 http://www.youtube.com/watch?v=3sFORkfhrY0 |
1990 mustang GT
i have a question aswell about the underdrive pullies, i got rid of all the accesories on my car now just have the alernator and power steering are there any underdrive kits for that or is my setup the best i can do?
All of the underdrive pulley kits I have seen include a crank pulley, alternator pulley, and water pump pulley so you would be able to use them all.
1990 mustang GT
what kind of numbers would i gain?
A couple horsepower.
they say like 9-15 hp but you wont see that at the wheels by no means
93 5.0 lx
My friend supercharged his 95 with a vortec.. gave me his crank and waterpump underdrive pulleys because he couldnt use them with the supercharger.. cant use the crank cuz it fucks up the boost.. and couldnt use the waterpump because of temp issues with the vortec
Heres an idea.. ban the ones that are most knowlegable and helpful in the 5.0 section...oh wait lmao |
2000 GT 'vert
You usually feel a better throttle response.
Sent from my Nexus One using AutoGuide App |
#15 | |
you might be able to get a pulley for the P/S but you can get deffo get different sizes for your alternator... i'm using a 200amp alt with an underdrive pulley, works wonders. Too small a pulley and you will wear out the bearings and brushes in the ALT quickly. Too large and you wont get a decent sustainable charge if you dont drive too often so id stick with the stock pulley if you have it... |
Threads Similar to: stock pullies vs. underdrives
| Underdrive/Stock Pullies | nero | 5.0 Mustangs | 8 | September 4th, 2008 11:27 AM |
| What pullies do I need to revert back to stock? | 03_StangGuy | 99-04 | 6 | July 16th, 2008 05:06 PM |
