351w
Old May 13th, 2007, 05:42 PM   #1
javier351lx is on a distinguished road
351w
Im swaping a 351w carb into a 89 5.0 does any one have any kinds of tips or hints that i should do?
Old May 18th, 2007, 02:11 PM   #2
punkafi888 is on a distinguished road
get new gaskets. make sure you do it right. and get a new carb not a used one.
Old May 18th, 2007, 05:10 PM   #3
TurboLX's Avatar
1988 Mustang LX Turbo
stronger motor mounts
Old May 18th, 2007, 06:39 PM   #4
ckthecerealkiller is on a distinguished road
Make sure you go with NO CAT'S it will make ears bleed when necessary! Other than that you will need to make sure your car can handle that kind of power of course but that is pretty standard stuff. The only thing I can think of is that I have heard ghost stories on some I beam setups. So H beam all the way!
Threads Similar to: 351w
302 351w notsoslow50 5.0 Mustangs 6 July 26th, 2007 01:14 AM
11 Second 351w drthunder7 5.0 Mustangs 21 May 27th, 2007 12:06 PM
351w dragpipe General Tech 2 May 2nd, 2007 08:53 AM
351w FastBack71 94-95 6 February 4th, 2007 04:40 PM
351w ecu? 5-0stank 5.0 Mustangs 6 January 7th, 2007 02:13 AM
