Car dies at idle...sometimes
Old July 1st, 2011, 11:49 PM   #1
jonrhy05 is on a distinguished road
only had the car a week, and about once a day, sometimes 2 or 3, the car dies at idle...after jumping from a couple hundred rpms, up o 1000 for a couple seconds. ive changed upper intake gasket, and ordered a new IAC gasket, the only vacuum lines that i can see are the 2 comin off the upper intake, and somethings blocked off on top of the throttle body...any other suggestions.
Old July 2nd, 2011, 12:12 AM   #2
1990 Mustang GT
Stevo077 is on a distinguished road
Is it running rich?
1990 Mustang GT
Old July 2nd, 2011, 02:08 AM   #3
1993 Mustang GT
fb93 is on a distinguished road
Sounds like idle surge. Is this for the Fox? Engine mods? Does it have a chip? Id start by cleaning the IAC and PCV valve filter using carb cleaner. Also check the TPS voltage, and fuel pressure. If its MAF, the sensor could be dirty. If the timing is off just enough it can mess with the idle. When was its last tuneup? Plugs, cap, rotor, wires, air and fuel filter? Wouldnt hurt to check all the vac lines and hoses as they wear out with age.
And the top of the throttle body (for a Fox) has a hose leading to the side of the oil filller on the passenger side valve cover.
Old January 28th, 2012, 12:22 AM   #4
Foxbody5.0
1987 Mustang GT
1987GT5.0 is on a distinguished road
I'm havin the same issue... I think it's an amperage problem, if I resolve it I'll tell you what it was... If you'll do the same for me lol
Threads Similar to: Car dies at idle...sometimes
91 mustang hunts for idle & dies kwtrucker 5.0 Mustangs 3 April 10th, 2011 12:19 PM
2003 3.8 v-6, Dies on idle!! NEED HELP!! ggipson79 V6 Mustangs 24 July 26th, 2010 12:48 PM
Wont idle, dies after let of gas Stangin94GT 5.0 Mustangs 20 July 24th, 2010 01:38 PM
START IDLE, RUNS THEN DIES slownomo All Other Vehicles 6 October 6th, 2007 11:20 AM
Rough Idle and Almost Dies After Warmed Up Gallie 5.0 Mustangs 10 April 12th, 2007 08:27 PM
