1986 Mustang 5.0 HO speed density to MAF
Old May 13th, 2007, 11:12 PM   #1
1st fox body is on a distinguished road
Have the 1986 Mustang 5.0 HO .Iwant to switch from speed density to MAF. I found the sensor and the computer in the junkyard . Where's the best place to buy the wiring harness . You guys hae helped before , please again, Pictures soon.
Old May 13th, 2007, 11:56 PM   #2
jam77's Avatar
1987 Mustang GT
jam77 is on a distinguished road
I would check on e-bay i find alot of good stuff there.
Old May 14th, 2007, 12:57 AM   #3
chadjones99's Avatar
chadjones99 is on a distinguished road
stay away
i would not go maf unless your going turbo or supercharge ,etc
speed density runs a little stronger in stock form. plus all the work and money to change it over.
1986 stang ,Edelbrook intake, aluminum heads, E303 cam ,70 MM throttle body ,24lb injectors ,373 gears , 10:1 pistons set up,no cats , flowmaster mufflers , short shifter , 255 fuel pump , smog pump delete , A/C delete , Aluminum Radiator , MAF convertion
Old May 14th, 2007, 09:27 AM   #4
Big timin' in a small town
Drick's Avatar
2004 FX4 F150, 86 GT
Switch to MAF if you plan on putting on heads cam and intake speed density does not perform well with these upgrades
Old May 15th, 2007, 12:37 PM   #5
Thanks guys. I do intend to do additioal upgrades , such as cam & heads. Your help is greatly appreciated. Thanks again.
Old May 15th, 2007, 07:13 PM   #6
86blkmustang's Avatar
86blkmustang is on a distinguished road
Send a message via AIM to 86blkmustang Send a message via Yahoo to 86blkmustang
Mustangs Unlimited has a 86-88 Mass air conversion harness for 34.95!
Old May 20th, 2007, 08:14 PM   #7
Thanks 86blk I checked on Mustangs Unlimited found the part and is ordered. Thanks again . This company looks like a good prospect for my parts for more mods. Let you know how the change over works in a week or 2.
Threads Similar to: 1986 Mustang 5.0 HO speed density to MAF
Cai for Speed Density Drick 5.0 Mustangs 16 September 19th, 2007 11:20 AM
87 SPEED DENSITY CAM HELP, SOME ADVICE ON THIS SET UP jers87mustang 5.0 Mustangs 7 September 18th, 2007 02:43 PM
Speed Density VS MAF Tr1gger 5.0 Mustangs 7 April 17th, 2007 11:24 PM
Speed Density or MAF? 8A_Honda 5.0 Mustangs 15 February 6th, 2007 09:04 PM
Speed Density Darrellx14 5.0 Mustangs 4 December 2nd, 2006 09:50 PM
