stuck o2 sensor
im pretty sure its an o2 sensor that broke because it looks like one but its on some pipe by the oil pan and it just broke off and the Nut or whatever looks like what needs to be turned with a wrench is kinda stripped... plus its on tight as tits... is there anything i can do
#2 | ||
88Notch 10.59 @132 / 03 Mach 1 13.1 @104
If it is located on the H-pipe then yes thats the O2 sensor. If the sucker is stripped and there no way to back it out.. There's 2 options.. Get a new / upgrade to a after market Mid Pipe, oorrrr Drill a hole, weld on a bung and replace it. My vote if you can't back it out is replace with a nice O/R mide pipe!
Military Crew USMC
1988 Mustang GT
13.27
I used a big pipe wrench with a cheater on mine, could try that
1993 Mustang GT
Could be hung up on a little rust. Can you fit an impact wrench up there?
If not then try some WD40 or something and let it sit a bit, then whack it a few times with a hammer. Or if youre good with a torch you can try a little heat. Or if the nut part of the sensor is rounded a bit try grinding it down the next size smaller and try again. You could try a vise grips but if its as tight as you say it might not do the job. Or just cut the welds for the bung and pull it and the sensor off as one piece, then weld another bung on there. |
1991 Ford Mustang GT
If and when you get them out, before you put new ones in , put anti seize on the threads
Also you could try heating up the H-pipe then through some big vice grips on there
1991 Mustang LX 5.0
Grind down and pound on the next smallest socket that you can get on there. Make sure you are using 6 point (hex shaped) sockets and not 12 point. 12 point is only good for 12 point bolts, lol. I'm slowly working on swaping all my 12 point crap out of my toolbox except for the 1/4 in drive stuff.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
Threads Similar to: stuck o2 sensor
| P0141 O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 2) | Shaun03GT | 99-04 | 23 | March 19th, 2011 12:08 AM |
| Stuck | 2VSouth | 99-04 | 4 | February 20th, 2011 01:48 PM |
| o2 sensor stuck lean (need help!!) | cbass105 | 99-04 | 6 | January 7th, 2011 04:23 AM |
| Im stuck on this one | nightrunner | 5.0 Mustangs | 4 | April 25th, 2009 07:27 PM |
| acc stuck on???? | 2006greyGT | 2005 - 2010 | 0 | April 13th, 2008 05:16 PM |
