Camber Correction maxed out
Old July 16th, 2011, 12:44 PM   #1
hfjeff's Avatar
1993 Mustang LX
hfjeff is on a distinguished road
Since the day I bought my vert I noticed the front wheels are tipped in on the top-the driver side much more noticeable than the passenger. I took it in to a very reputable local alignment shop and they were able to adjust the passenger side, but driver side they said is maxed out. They drilled out a rivet which was in the middle on the passenger side, but already on the outside edge on the driver side. I asked if that meant something is bent or damaged and they said no-that is just the design. The driver side is still tipped in on the top a little. Any way to correct this or is it supposed to be tipped in slightly?
93 LX 5.0 Vert, 3:55's, Fresh T5
Old July 16th, 2011, 12:49 PM   #2
Timm10221's Avatar
88Notch 10.59 @132 / 03 Mach 1 13.1 @104
Timm10221 is on a distinguished road
Sounds like its time for Caster/Chamber plates... do you have drop springs on the car???
Military Crew USMC
Originally Posted by JBIGBOOTSY
I usually kill the hookers(so I don't have to pay them) then I take their hands for my collection.
Originally Posted by homebrewed
Perversion mixed w/ mild tech... God I love ModdedMustangs!!
Originally Posted by flyin ryan View Post
Three Filipino hookers and enough for a co pay at the local clinic
Old July 16th, 2011, 02:30 PM   #3
hfjeff's Avatar
1993 Mustang LX
no dropped springs. I actually had them install spring spacers to lift the front 5/8" since it was hangin too low compared to the rear. That combined with the camber issue made it sit like I had a 460 under the hood.
Old July 16th, 2011, 03:50 PM   #4
OmniEquipped's Avatar
OmniEquipped is on a distinguished road
My brother's '91 has the same issue. Alignment shop told him the same thing. It's been like that since he bought the car in '95 and there is no sign that it has ever been wrecked. I think he tried spring spacers as well. The car steers and drives great and the negative camber is not that noticeable unless you look for it, but it does prematurely wear the inside tread of the tires.
My 5.0 - View the vitals here.
Old July 16th, 2011, 04:11 PM   #5
PhillyGT's Avatar
2001 Mustang GT
13.8@101.58mph!
PhillyGT is on a distinguished road
I have a similar problem.Must be theses damn verts!
Dropped on Eibachs,K&N FIPK,Mac-prochamber o/r,Flowmasters.Short throw,Heavy Right Foot Mod
Old July 16th, 2011, 06:26 PM   #6
hfjeff's Avatar
1993 Mustang LX
The car drives and steers fine. I don't think it was ever wrecked. I see plenty of vettes and other cars with the rear wheels tipped in so I know it isn't just this car. Just bugs me every time I look at it. I trust the shop I took it to but was wondering if anybody knew of some aftermarket part the would correct it. Probably not worth the $$$ or effort to make it pretty.
Old July 17th, 2011, 02:59 AM   #7
1993 Mustang GT
fb93 is on a distinguished road
How much of the front end is still factory? Could be a sagging spring, worn front control arms bushings, bad ball joints, or bad tie rods. They all play a part to some degree when it comes to alignment.
Old July 17th, 2011, 05:41 AM   #8
1988 convertible's Avatar
1988
1988 convertible is on a distinguished road
Send a message via Yahoo to 1988 convertible
As above you may have to pull the front end apart. have a look to see if the rubber insulators are worn out in the cups and on the top of the springs and also the amount of travel on the shock absorbers... those are the main parts to look into for height adjusting and will determin if you can get the proper alignment before fiddling with the caster/camber settings...
inspect the lower control arm for any damage/warpage...
sometimes its just the course of a verts natural life where the chassis twists from not being ridgid enough it puts pressure on certain areas of the frame and that all travels to integral joints on the car... my vert is a little bent out of shape as well but after an overhaul on the front suspension and some CCplates its all looking like it should again
dont know if this is any help to you but i found it copied in the back of a mustang manual... took a picture of it so i wouldnt forget it...
camber = -0.50deg + 0.75deg
caster = +1.9 deg + 0.75deg
toe-in inches = -0.12 + 0.12inch
toe-in degrees = 0.25deg + 0.25deg
front wheel turning angle full turn
inside/outside = 20.00deg/19.84deg
Old July 17th, 2011, 09:31 AM   #9
PhillyGT's Avatar
2001 Mustang GT
13.8@101.58mph!
20 years of doing the twist might play a part in it.CC plates next
Old July 17th, 2011, 12:08 PM   #10
hfjeff's Avatar
1993 Mustang LX
I had the alignment shop inspect the front end-again I trust the work at this shop. The stock adjustment doesn't allow for much movement. I agree that these frames aren't that strong and can warp over time. I wasn't aware of CC plates and he must not have been either. They are not that expensive for a 90-93-Only $189 from American Muscle.
http://www.americanmuscle.com/caster...es-mm9093.html
That's what I needed to know. Thanks again guys.
Old July 17th, 2011, 01:59 PM   #11
Dap1991's Avatar
91 GT 90 LX 5.0
Dap1991 is on a distinguished road
ya heard that about the stock stuff, the problem really is ford just didnt put enough adjustability in them, to correct you need cc plates, my notch has every rivet drilled out lol so some one must have messed with it alot
1991 GT- All Stock
1990 LX 5.0- CAI, Shorty headers, flowmaster, Tubular Upper and Lower Control arms, Tokico HP series, Eibach Springs
Threads Similar to: Camber Correction maxed out
Took car for alignment.. Maxed out?? warrior86 2005 - 2010 7 April 21st, 2011 07:34 AM
Maxed MAF Black Baby II 2005 - 2010 4 December 16th, 2010 10:10 AM
Tuner assistance (maxed out maf?) mystang0673 99-04 9 April 9th, 2010 09:52 AM
19#ers maxed yet? superbean 5.0 Mustangs 15 August 3rd, 2009 01:31 PM
