Question about 331 and stock computer???
Hate being the "new guy".... Anyways my question is, I have a lightly modified 91 LX. The engine just isnt cutting it for me. I am planning on putting a 331 or 347 in it, but was unsure what I would have to do about the stock computer. I know that the injectors woudl have to be upgraded along with the MAF to match the injectors. I already have a pair of headers, and am plannign on gettting a set of 185' ARF heads. So does anyone have any idea what id have to do about the puter? Or how hard would it be to do a conversion to carb?
any help would be greatly appericiated. |
1988 Mustang LX Turbo
a carb would b easier but if the car is already a V8 then its just even more easier, try a Stand alone system for your EEC problems
1988 LX Coupe 2.5L, GT35R, 44mm WG, 32psi, C16. |
Thanks for the help...
You should not have much if any trouble at all with the computer unless you plan on using injectors 42lbs or larger.. If you build that motor and use 36lb injectors or smaller you will be fine.. You still will need to get a tune done and a chip burned for it to run right..
#5 | |
9000 hp, 170 knots, 9 aluminum drive shafts, 3 piston disk brakes, can carry 9 camaros to the junkyard at the same time. |
Threads Similar to: Question about 331 and stock computer???
| Quick Question bout Computer | 06RoushStage2 | 2005 - 2010 | 8 | October 27th, 2007 01:31 PM |
| Flowmasters on Stock GT Question | wilburgtwoot | General Tech | 11 | July 10th, 2007 01:55 AM |
| computer question | mtndew | 2.3 Mustangs | 1 | May 20th, 2007 10:49 PM |
| Stock scoop question. | DrHolliday | 99-04 | 23 | April 20th, 2007 07:15 PM |
| computer question | sb2f5marine69 | 5.0 Mustangs | 12 | March 6th, 2007 09:43 PM |
