302 swap??????????
ok i have a v6 an want a v8 well 4.6s are a bit pricey i have shops an tools i can use so install wont be a prob how much horse could i pull from a newer 5.0 around the 90's an possibly find some 351 high flow heads for it???
With a good mild H/C/I 275 to 285 hp. You can do more to a 5.0 than you can a 4.6 with less money. Or you could go 351 cheaper than a 4.6. Those 351 heads were high flow heads along time ago. Now we actually have high flow heads in the aftermarket, but I guess the 351's are cheaper. The stock block is only good to around 450 hp or a little less.
9000 hp, 170 knots, 9 aluminum drive shafts, 3 piston disk brakes, can carry 9 camaros to the junkyard at the same time. |
Threads Similar to: 302 swap??????????
| Which one is easier??a rear end swap or engine swap? | Bies08 | V6 Mustangs | 42 | May 11th, 2010 05:33 PM |
| PI Head Swap and Transmission Swap | jEEd | 96-98 | 18 | May 14th, 2009 01:57 AM |
| Can't decide, engine swap or PI swap? A few questions... | k3vin | 96-98 | 24 | September 5th, 2007 07:48 PM |
| 3.8 swap to 5.0 | goldhorse | V6 Mustangs | 1 | August 10th, 2007 01:57 AM |
| 351 Swap | Cskit1500 | 5.0 Mustangs | 6 | November 16th, 2006 08:40 PM |
