gas pedal............
Old May 16th, 2007, 04:32 AM   #1
1989 GT Hatch
YNOT is on a distinguished road
........stuck down while driving home tonight.
Old May 16th, 2007, 06:47 AM   #2
neverfastenough's Avatar
neverfastenough is on a distinguished road
Man that sounds like fun! I used to have a pickup that every time the floor mat slid forward and got under the pedal it would stick when I mashed it all the way to the floor. It could be the springs, the cable or more commonly carbon buildup in the throttle body. I'd start by cleaning the throttle body. You can break it down into sections to eliminate and rule out parts if it keeps doing it.
9000 hp, 170 knots, 9 aluminum drive shafts, 3 piston disk brakes, can carry 9 camaros to the junkyard at the same time.
Old May 16th, 2007, 10:01 AM   #3
88dragstang is on a distinguished road
A friend of mine had that happen to him last friday at the local dragstrip!
Its an 1/8 mile track and he went through the big end stuck wide open at 99.5 mph. He shut the key off and hit the sand but he and the car are ok. Same situation, pin down floormat caught the pedal. He did run a 7.18 though, LOL! Pretty fast for a 5 speed.
Old May 17th, 2007, 09:19 PM   #4
jpalm is on a distinguished road
also check the motor mounts, if it sticks when you get down on it, the motor may be lifting and binding the linkage/cable. be careful, good luck
jpalm
Old May 17th, 2007, 11:43 PM   #5
patwrecked is on a distinguished road
theres a bolt inter the throttle body with a spring behind it. If you loosen that up it should solve your problem.
Threads Similar to: gas pedal............
how to take the slack out of your gas pedal wadepetersen V6 Mustangs 18 October 4th, 2007 12:25 AM
gas pedal is all go gotime89 5.0 Mustangs 3 August 3rd, 2007 11:58 AM
Gas Pedal Mustang Mike 99-04 3 March 20th, 2007 09:27 AM
Gas Pedal itschristorres8 V6 Mustangs 32 September 24th, 2006 04:18 AM
Gas Pedal JRubin2000 99-04 11 September 22nd, 2006 01:31 AM
