Smoke From Shifter Boot
At idle, when I rev the engine high like to test or something at 2300k or up to 2500, smoke comes from the shifter boost. The smoke pushes like someone smoking a cig. It's been rare lately but it still happens. What could it be? And will someone please tell me the correct signal wire from the O2 sensor so I can hook up my A/F ratio gauge.
Thanks
THE BEAST IS FOR SALE!!! GTX RACING & PERFORMACE CLUB OF TEXAS Meets and greets, drag racing and good eats, you know you want it. GTX Racing Tony P. 214-257-3635 http://www.moddedmustangs.com/forums...vehicle&CID=43 |
do you have any exhaust leaks? that might be letting smoke into the cab?
i think your signal wire should be DG/P
#4 | |
Answering your last message... I was about to say "DG/P!?!?!?!?!", then I was like OH OK dark green/purple but you "Think" it is, are you sure? I mean signal wire on a positive connection would blow up my gauge. LOL it's ok imma try
Look Ma! My First Post!
I had smoke pour from my console way down by the boot one day.. and was clueless as to what was burning..
Turns out,... a month later my AC died.. I pulled the AC control panel and the plug on the back of the on/off switch had melted. It could be anything in the console all the way up to the AC, or back to the cigarette lighter. You got Shifter Lights in an Auto, AC Panel, AC Illumination, Stereo Cables, and Cigarette lighter wires inside the console. |
i had the same problem but smoke only came out when i was cruisin. check if your pcv valve popped out of the grommet or intake manifold
85 svo. work in progress
Threads Similar to: Smoke From Shifter Boot
| Shifter Boot | Boris | 94-95 | 5 | October 12th, 2007 07:24 PM |
| Replacing Shifter Boot | Mach Boy | 99-04 | 5 | October 4th, 2007 11:47 AM |
| Lower shifter boot | kwill5 | 96-98 | 6 | August 11th, 2007 03:01 PM |
| Smoke from the Shifter | GTXRacing | General Tech | 15 | May 21st, 2006 12:51 AM |
