#21 | |
modded 95 gt vert
i can help you with this one. When i first got my car it was all stock other then a bbk coi, trick flow stage 2 cam, bbk shorty headers, flowmaster exhaust and a set of gt40x aluminum heads. With no tune the car put down 213.8rwhp and 280.8rwtq on the dyno and the a/f ratio was very good at 12.8 so i wondered why my numbers were so low? So i then added a 95 cobra upper and lower intake setup port matched and polished to the gt40x heads and honed a little of the intake to match a 70mm throttlebody, 30# injectors, bbk coi, aluminum underdrive pulleys, smog and ac deletes, and a 255lph fuel pump and the car jumped up to 262.7rwhp and 308.1rwtq. I could have had it tuned and knocked on 300rwhp door but i had other plans. That was my first lesson on how to properly match up bolt ons for max power. They all have to work together for the best gains. Now as far as sticking to all ford racing stuff more power to you as i did the same other then adding a turbo kit. The cobra intakes are great for the street as they are tuned for torque. They dont produce as much hp as the others like trick flow and holly but the torque numbers are no match compared to the the cobra stuff. Good luck!
BLACK ON BLACK 95 GT VERT FULLY CONVERTED TO A 95 COBRA AND MODIFIED WITH ALOT OF GOODIES AND A BB SINGLE T67 TURBO KIT. 526.14RWHP 496.00RWTQ @6PSI. RAN OUT OF FUEL @5500RPM PROJECT CAR AKA MONEY-PIT LOL!... TUNED BY GEORGE @ AKRON HP.
#22 |
thank you man !
#23 |
Priest of the Car Gods
Wow... that is really bad... my 5.0 dyno'd at 194/269 to the tires with nothing but a drop-in air filter, dumped magnaflows, and synthetic oil.
#24 | |
2009 Mustang GT
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
![]() you can't keep it original and use aftermarket parts. and there's no such thing as original aftermarket parts, unless you're referring to something like the iron GT40 heads, which were original on a cobra, not your 5.0
#25 |
modded 95 gt vert
ya the numbers were lower then usual because the pulls were done on a dyno dynamics dyno and theyre known for being very conservative. All of my other pulls and tunes were done on a dynojet and the numbers were alot different.
Threads Similar to: Ford Racing Turbo-Swirl GT40X Aluminum Head
| Ford Racing Aluminum Driveshift | Barricade81 | V6 Mustangs | 24 | January 7th, 2011 01:25 PM |
| Will a aluminum 5.0 ford racing driveshaft work in a 2.3L w/5spd? | Smokestang88 | 2.3 Mustangs | 3 | January 7th, 2011 11:45 AM |
| ford racing aluminum driveshaft | tjames | V6 Mustangs | 36 | July 7th, 2010 09:35 AM |
| FORD RACING GT-40X TURBO-SWIRL ALUMINUM | stang94 | 5.0 Mustangs | 11 | December 27th, 2006 12:58 PM |
