Not Cool!
Old August 2nd, 2011, 05:03 PM   #1
1990 5.0 LX SSP
Colt.45 is an unknown quantity at this point
Not Cool!
I know this is an old subject but please bear with me. I have an alum. rad.,Black magic Extreme 185 fan, flex a lite vsc, 180 t stat, and victor Jr. water pump. When the fan comes on and runs at 60 -100% I run a smooth 190 degrees with a/c on and 100 degree temps. The prob. is it does not always do that. Is it a simple matter of breaking the hot wire with a switch for manual operation, or do I need some kind of relay or something. I really don't want to go back to my stock set up. Any help will be greatly appreciated. I'm about to have a double hissy duck fit!
Old August 2nd, 2011, 05:34 PM   #2
HMERacing's Avatar
89 FOX/01 WS6
0@0/13.1@106
HMERacing is on a distinguished road
http://www.sportcompactonly.com/manu...-54996-RAD.pdf
Wire up the manual switch and be done!
Mike
1989 Mustang LX, 2001 Transam WS6
Originally Posted by 302Army187 View Post
I'm going to install an U pipe.
bitch is going to re route the exhaust pulse back out of the intake between intake pulses.
Old August 2nd, 2011, 10:40 PM   #3
nolife's Avatar
91GT, 88GT, 02GT
I don't understand.. What is the actual problem?
In theory...
The fan setpoint should be about 10-15 degrees higher than your mechanical thermostat. The thermostat will start to open at its setpoint and be fully open about 10 degrees higher. When it is fully open and temperature is still creeping up, eventually the fan will turn on (or speed up with a variable controller) and cool it back down. This minimizes the wear and time your fan has to run and allows full water flow through the engine and radiator. With the fan probe stuck in the rad fins, it takes a little playing around to get the right fan setpoint as that temperature there is not the same as the water in the engine. On that note.. 190F is no where near "too hot" for a car to run and there is no advantage of going out of your way and trying to keep it there. 215-220F is normal with the AC running in hot weather.
Old August 3rd, 2011, 09:13 AM   #4
1990 5.0 LX SSP
If 215-220 is normal, then maybe I don't have a problem. That would be great. I was afraid it might be a little warm for alum. heads. Unless it gets really hot out, I normally run 188- 190. In slow traffic or in town I hit 220. I'm sending the temp.reading to the controller from the coolant lines that use to go to the egr plate. If I were to go manual, would an oem light switch handle it. I have a dummy switch on my dash I could replace. Can I run a manual switch as an aux. so I could turn it on 100% in town? Thanks y'all all help is greatly appreciated.
Old August 3rd, 2011, 09:45 AM   #5
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
You're fan isn't on a relay? I would always put a relay in.
./___ _ ____ ___ \.
( ]]] _ _ O _ _ [[[ )
\_ o _ _____ _ o _/
|___| ......... |___|
Old August 3rd, 2011, 10:54 AM   #6
1990 5.0 LX SSP
To be honest, I'm not sure. If you're talking about a fuse relay,I have a 40 amp fuse. It's a standard flex a lite fan and vsc. I just heard someone say something about it one time. So I was just trying to get straight in my head. I've done a lot of industrial elec.work, but very little control or dc work.
Old August 3rd, 2011, 01:47 PM   #7
1990 5.0 LX SSP
In theory...
The problem is the controller is not bringing the fan on when it should , consistently.. Drove 15 miles into town just now. Outside temp. is 100 degrees.All the way there @60mph with a/c on it ran 188. Got into town stopped at the atm and before I could finish my transaction I was at 220. Three blocks away I was at 240.I freaked and got about 5 shades of pissed. Parked my car and the fan was barely spinning. I watched the gauge rise to 250, then the fan finally decided to come on. When I came back out of the store it was at 160. All the way home with no a/c 188-190. After 1/2 mile of drive way @1500 rpm 1st gear,192. The fan was at about 60% then went to 100% shortly. So I think my controller is junk, or at the very least, unreliable. What do you think?
Old August 3rd, 2011, 02:32 PM   #8
nolife's Avatar
91GT, 88GT, 02GT
Okay, I see now. Where is the temp probe for the fan located? Is it shoved in the rad fins somewhere? You could have an electronic problem with the controller but my first guess is the probe is not in a place where it is getting consistent accurate temperature readings and not turning on when it should be. The fact that it only heats up when you are standing still does point to an air flow issue and not likely a stuck or sluggish thermostat. I would troubleshoot the probe before hard wiring the fan. Off the top of my head, I would say move it around and hell, maybe even hold it close to a hot header pipe for a few seconds and see if the fan speeds up. One of those cheap infrared thermometers would help you troubleshoot.
Old August 3rd, 2011, 04:51 PM   #9
1990 5.0 LX SSP
I don't have the original controller with the rad. probe, it didn't last long. I used a3/8" " T " with barb fittings in the ends and the sending unit in the center. I put this contraption in between the egr coolant lines that I have long been disconnected. I have a laser thermometer (+ - 1 degree). The temp. readings on the " T " , t-stat housing and the heads generally correspond to my temp.gauge. For summer coolant, I use distilled water and 2 bottles of RP's Purple Ice. I have the set point on my fan as low as it will go. As long as the fan comes on when it should, all's well, but it doesn't. That's why I'm thinking about a manual switch for back-up.Every part on my car has less than 15,000 miles on them. A friend of mine and I dd a complete build, bumper to bumper, tires to roof. Without cutting corners on parts. Other than this cooling thing, it' a pure blast to drive. I would not take a golden guinea for it.
Old August 3rd, 2011, 08:25 PM   #10
nolife's Avatar
91GT, 88GT, 02GT
Sounds like your rig although mechanically sound and a good idea, does not work for some reason with your specific temperature sender or the electronics for the fan. I am not familiar with the BM fan and the type of probe or signal levels it uses to manipulate the fan. I looked at the install instructions for that fan which are here. You probably need their probe for the the thing to work correctly. Maybe they sell that as a replacement part separately. Call them and find out? Either way, if your setup was wired per their instructions, it shows how to install a manual override like you want. It looks like a simple 2 wire hookup (or 3 wires if you want a lighted switch) and probably any switch with at least a 12v 1A rating would work.
Old August 3rd, 2011, 10:45 PM   #11
HMERacing's Avatar
89 FOX/01 WS6
0@0/13.1@106
You may not be able to replace the probe. If it is like an autometer water temp guage, once the line of probe is damaged the guage is trash.
Mike
Old August 4th, 2011, 09:38 AM   #12
1990 5.0 LX SSP
The controller that came with the fan had a probe.When it came on it was 100%. The prob. with it was the rheostat got so finicky. My cousin gave me this vsc that he never used. The vsc is a Flex a lite controller, and is a much better made piece than the original.The sending unit is designed to screw into a head or something. I'm picking up true water temp. now vs. rad. temp. with the probe. As soon as get my coffee fix, I'm going to study on a manual override or maybe reinstalling my original controller. I'll probably do the manual override first and see how that works out. That way I can still have the benefits of the vsc (when it works right). If not, go manual to save the day. I really appreciate every bodies help. Thanks
Old August 4th, 2011, 10:05 AM   #13
1990 5.0 LX SSP
The diagram shown is for the original controller. It's a single speed deal. Mine is the vsc, but that's okay.I found a diagram for it. Wiring a man. switch should be a walk in the park.
Old August 8th, 2011, 01:43 PM   #14
1990 5.0 LX SSP
Now it's official ! The Flex A Lite Black Magic 185 Extreme elec. fan was a Royal Pain In My Ass ! My controller was not the problem, it was the fan motor. It had been getting hot and quitting, before just stopping altogether. Good news is my SSP clutch fan went back in without a hitch. Hasn't been over 190 yet. So far , so good. BAM ! Case closed.
Old August 8th, 2011, 10:18 PM   #15
cleangtvert's Avatar
1991 gt vert
cleangtvert will become famous soon enough
another BM fan bites the dust! that sucks colt.45. i doint think those high dollar fans are worth a crap on a daily driver. over the years and many differant forums for differant rides ive had. i've seen dozens of posts about $300 e-fans that failed. i got lucky finding two mark 8 fans. i have one extra if i ever need it.
Old August 9th, 2011, 04:09 PM   #16
1990 5.0 LX SSP
I think you are right. When it worked like it should, everything was honkey dory. But seemed like it's been a hassle of one thing or another. They warranty their motors for one yr. , mine lasted two. But less than 15,000 miles. I may start looking a mark 8 fan in case I get ticked with my current set up. No more BM for me.
Threads Similar to: Not Cool!
Cool Eyes Are Cool TheUNZippee! The Clubhouse 4 December 19th, 2010 05:55 PM
a cool DD? trueblue02GT The Clubhouse 42 August 27th, 2009 01:42 PM
How Cool Is this? TheUNZippee! The Clubhouse 27 March 11th, 2008 07:15 PM
Cool BMW upshift The Clubhouse 3 December 11th, 2007 12:07 PM
Now This Is Cool! TurboLX The Clubhouse 1 November 16th, 2007 12:30 PM
