1990 5.0 LX SSP
Throttle Bodies
I've seen people post about which is the best tb. Opinions on which is best vary as much as the prices . I'm on my 2nd Edelbrock tb, a 65mm and now a 70mm. Never had a problem with either one. My question is not so much which is better, but what makes a great tb? They all seem to be pretty straight forward, not a lot of obvious differences.
1991 mustang 5.0
I heard they are all made by the same company, then restamped for different companies. I had a BBK 70mm and had no issues with it. I hear accufab's are good too. But like I said, I think they are all made by the same company, or so i have read..
1993 Mustang LX
my dog runs faster...
No, they are not made by the same company.
Accufabs are the shit!
![]() MM+Cleavage Club Member #19
1990 5.0 LX SSP
A lot of people think so. But Why? They are basically a pipe with a butterfly to meter the air going into the intake. Does one flow better than the rest, or just higher quality parts. Maybe tighter tolerances, or all of the above?
89 GT
Holley TB's suck. Mine sticks off idle and then flings itself open when you put enough pressure on the pedal. My old accufab worked like a dream, smooth as butter. This holley is like an on off switch because it's poorly made IMO. I've had it apart and filed everything down and it still sticks.
1993 Mustang LX
Accufabs are just made REALLY well. From quality to tolerances, they are dead nuts. Like fogged said...smooth as butter. I ordered a pro products, accufab and bbk just to compare and the accufab was hands down above the rest. The others felt "cheap" from weight of material to construction.
#7 | |
1990 5.0 LX SSP
1991 Ford Mustang GT
Im running a 70mm accufab and i love it
1988 Mustang LX 5.0
Read this months Muscle Mustang and fast Fords there is an article about TS not whish are the best quality but more about size. Its pretty good and by this months I mean the one that just came out its either September or October. As far as Quaity Acufab is pretty much the best made out there followed by. There are rumprs that a lot of TBs are made by the same company. BBK and Edelbrock have the same manufacturer, but as fro as I know thats it. Even just by looking at a picture you can tell acufab is a lot different from a lot of the others. Iv seen TBs on Ebay stamped with BBK and Edelbrock tight next to it.
Rust is lighter than metal......right. |
1991 mustang 5.0
EH, if I had the money I would have an accufab just because they look nice to me. And i'm not really a fan of edelbrock anything. But my BBK worked just fine and was 1000000000000x better than the stock one lol
#11 | |
if you have an aftermarket man get one that matches that... their all designed to do the same thing so may seem the same but their not. many different composits of stainless/Aluminum are used to produce them... you cant go wrong with BBK, Accufab, Edelbrock or professional performance. im sure there are more im not mentioning but its personal preference to what brand you want to use... |
#12 | |
1990 5.0 LX SSP
#14 | |
1993 Mustang LX
the early BBK TBs were prone to cracking the shafts - junk! I guess Edelbrock fixed that when they bought the BBK TB line or BBK started making TBs for Edelbrock.
What really sucks is that BBK/Edelbrock will not sell replacement shafts for the older broke dik units due to "liability" concerns B-shit.
88 GT Vert 5spd, 3:73 gears, Explorer intake/65mm TB, Explorer Ps, Manley race 1.85/1.55 valves, 1.7/1.6 stud rockers, stock cam +4 degrees, MAC Jet-Hot coated shorties. 277RWHP/330RWTQ www.fastlanecars.com http://tmossporting.0catch.com/
1988 Mustang LX 5.0
So Digsj7 you had trouble reading my post because of the 10 mistakes I made. Im sorry you need things perfect so you can sound them out. You onestly had to post to knock my bad typing. Thanks for being helpfull.
#17 | |
1990 5.0 LX SSP
'06 Mustang GT
my bbk whistles due to the idle air control valve hole is to sharp and when air passes over it the damn thing whistles drive me crazy and sounds like smacked A$$
89 GT
this might be my issue that i was thinking was a vacuum leak and was having a hard time locating it
'92 coupe 5.0/5spd cobra intake, b-cam, gt-40's, mac shorties, mac h-pipe, mac catback, cobra 5lug w/ 3.55's |
Threads Similar to: Throttle Bodies
| throttle bodies | trufordblue00 | 99-04 | 8 | February 12th, 2010 10:08 PM |
| Throttle Bodies | whtpny | 99-04 | 28 | November 15th, 2007 06:40 PM |
| Throttle Bodies | jblood37 | 99-04 | 12 | February 6th, 2007 05:59 PM |
| Throttle bodies | Shadowfax | 2005 - 2010 | 2 | January 18th, 2007 08:15 AM |
| Throttle Bodies | JBake | V6 Mustangs | 6 | October 31st, 2006 12:50 PM |
