i hate u idle
ok so my idle rpm use to be around 800 now it jumps to 1500 and stays there..i clean the idle air control thingy and same shit.. i switched three others out and same thing.. what could be wrong???and everytime i switched them i took battery off.. then after put it back after switching them out... and waited couple seconds... and nothing.. i need help
1991 Ford Mustang GT
Did you check for vacuum leaks ?....Also try doing the base idle reset, Also check your TPS volt
1993 Mustang GT
If this just started and you havent messed with the throttle body recently, check for a vac leak first. Check both hard and soft lines with the engine off and running. Feel around the lower/upper intake gasket and check the pcv valve and filter under it. I wouldnt mess with the base idle until everything else checks out.
Its possible the upper intake is dirty. They can get pretty nasty which can affect idle. |
Threads Similar to: i hate u idle
| I hate, hate, hate these type of people. | shroom | The Clubhouse | 71 | May 24th, 2011 05:02 PM |
| [pics]My fish tank headlights at night. The lights you love to hate and hate to love. | MustangGeek | Pictures | 85 | May 7th, 2011 06:21 PM |
| I hate HD2's. I hate flashing android | Imran | The Clubhouse | 23 | February 10th, 2011 02:48 PM |
| Idle Problems Code 1506, Idle Overspeed Error | jagstang96 | 96-98 | 3 | August 29th, 2006 04:11 AM |
