1993 mustang gt
stock
gas gauge issue sage advice needed
as you can see in this image the gas gauge is pegged and stays that way on or off this is a 93 gt
1993 mustang gt
stock
that is off if you cant tell the battery gauge and all other gauges work properly
1993 mustang gt
stock
plz help i gta get this fixed this a new car and i have no idea how much gas i have so i keep pouring money in it just to be sure which kinda sucks.........
1993 mustang gt
stock
Hellllp
1993 Mustang GT
Could be a bad fuel sender, anti slosh module, the gauge itself, or wiring. When did the gauge stop working? Did you install the white face gauges or someone else? Has the fuel tank been dropped recently?
1993 Mustang GT
double post.
the first thing id do is ditch the white face gauges and go from there, not saying thats ur problem, my gas gauge is also goofy but i can gennerally get an idea where its at. does yours move at all? if it doesnt move at all id be more then willing to bet the needle is stuck on those white face gauges
1991 Ford Mustang GT
I had this issue, my problem was the anti slosh circuit board that is plugged into the back of the gauge cluster above the fuel gauge only 1990-1993 had this circuit board
Latemodelresto.com calls is a instument volt regulator 1990-93 Mustang Instrument Voltage Regulator by Ford at LRS - Same Day Shipping!
1993 mustang gt
stock
It doesnt move ever i bought it like this just a few days ago im kinda in a bind because im putting in alotta money and i cant tell when im gna run out i assume the gauges were put on by the previous owner he took care of it this thing is mint on the inside
it doesnt matter if he took really good care of it....Things just brake( wear out) and that gauge cluster only has a white face sticker on it. electrical stuff break down all the time. you have to understand that if your going to buy a car thats 18 years old its going to have problems regarless of how well it was taken care of. This is not going to be the last time your going to have to put money into this car so you better get use to it. My advice is to not have a mustang as your primary car, It should be a weekend car/project, unless you have the money to drop into it all the time.
A few years back i ran out of money when it came to making repairs on my mustang and i finally had to park her away and get a trust worthy newer toyota truck. and when i finally had enough money years later, i pulled her out of the gerage, and got her going again. Now its just a fun car a drive a few time a month
1993 mustang gt
stock
This car is pretty mean even stock i coulda bought alotta cars straight out cash i wanted this paticular car because i love the look i watched cars like it on the drag strip growin up and i always wanted one
1993 Mustang GT
If possible, ask the previous owner if the gauge was bad before or after the gauges were swapped.
Regardless, pull the dash cluster off and make sure everything is connected, no wires are pinched, and there are no breaks, tears, or burnouts in the printed circuit, and make sure the anti slosh module is where it should be. It snaps into the back of the cluster. According to Ford they cannot be tested. And be careful with the printed circuit, its fragile, and cannot be repaired if broken. If everything appears good, you will need a digital voltmeter to check things out. |
1993 mustang gt
stock
Im taking it to a good local shop tommorow thnx for the advice guys im new here and dont have any real foxbody friends i got pics up check em out i just got this car and ill never sell i luv it its in very good shape after the gas gauge is fixed all i gta do is prep and paint
1993 mustang gt
stock
I will repost the shops diagnosis when its back i probably will have a panick attack while its gone
why does every one think that his gauges have been replaced ? All he has is a WHITE FACE STICKER that you can buy off ebay. You can slap that stick on any old fox body gauges
1993 mustang gt
stock
i changed the oil now im getting the gas gauge fixed then possibly some 373s then who knows im thinkn definately shaved door handles and new suspension parts the engine is probably gonna get a bunch of chrome pulleys and chrome brackets along with a supercharger in a few months new paint to follow all the performance upgrades then new wheels to end the project
1993 mustang gt
stock
![]() here she is today i mighta cleaned it up a little |
1993 mustang gt
stock
That black shit n the driveway aint from her either it was from a old 66 impala that was pretty mint until a older lady rear ended it and bent the frame n twisted the nice dual exhaust all to hell
1993 mustang gt
stock
Actuallt tryin to get rid of it for 1500 ( the chevy that is)
1993 mustang gt
stock
The cost so far is 148 there was a wire loose behind the dash i took it home to the gas station filled it up and the tank reads half full then i take the car back to the shop and they call n tell me its the fuel sending unit gna cost me anothr 250 to 300 shit i got the doe and it dont hurt my checkbook a bit but it still makes me sad to see 500 bucks blown on a small issue like this
Threads Similar to: gas gauge issue sage advice needed
| 89 gt oil pressure issue help needed | foxcoupe | 5.0 Mustangs | 11 | May 10th, 2011 10:44 PM |
| help needed with no start issue? | osa6637 | 99-04 | 4 | December 27th, 2010 10:54 PM |
| Tuner/ sct program issue? Help needed! | 02StangGToWNEr | 2005 - 2010 | 16 | September 1st, 2010 08:24 PM |
| Opinions needed! Leak Issue | redeluv | General Tech | 2 | June 12th, 2008 09:37 PM |
