vibration
in ma 89' gt whenever i pull off from tha light i can kinda feel a vibration coming from somewhere but im not sure where it is, its coming from the front passenger side of the car,, do u think that i need to replace the control arm bushings?? wht do u think is causing this
1999 Ford Mustang V6
i'd inspect the brakes first
...even fire and single cammin 1986 Ford F-150 5.0L 2WD 1994 Toyota Pickup 2.4L 4WD 1999 Ford Mustang 3.8L V6 2002 Jeep Grand Cherokee 4.0L 2WD 2008 GMC Sierra Denali 6.2L AWD |
Exhaust?
can you describe the vibration at all. Is it almost like a thumping or is it more of a solid vibration. Check and make sure your exhaust is not rubbing somewhere. Check engine mounts and check like you said all of you suspension bushings.
i feel it only when i take of from low rpm,, if i take off at about 1500 rpm then i wont really feel it but anything lower than that i can feel it in the pedals sometimes and in the steering wheel and you can hear it,, its gotta be the bushings i think..
kinda like something is rubbing |
I am thinking your motor mounts are bad
Lower control arm bolts tight?
Threads Similar to: vibration
| Vibration | graystang01 | V6 Mustangs | 21 | December 15th, 2007 11:23 PM |
| vibration | haywood11 | 5.0 Mustangs | 2 | October 28th, 2007 08:41 AM |
| Vibration | shurb125 | 5.0 Mustangs | 13 | May 8th, 2007 09:23 AM |
| vibration | hmotes | 5.0 Mustangs | 8 | January 5th, 2007 02:30 PM |
| vibration | cali 5.0 | General Tech | 2 | May 31st, 2006 05:09 PM |
