Mustang Fanatic
1989 Mustang LX
Trick Flow track heat intake on AFR 185's
I sat the intake on the motor yesterday and noticed that the intake ports don't match up too well.... Ive been told this is a really good intake, but I'm pretty sure mismatched ports is not a good idea to just leave it alone..
What should I go about doing with this?
89 Mustang LX: 347 AFR Comp Cam TFS Track Heat 359rwhp 395rwtq
port match with a dremel. lay an intake manifold gasket on the head and intake manifold, trace the opening with a sharpie, then grind each side out until its flush with the gasket. sadly, this means removing the head from the engine, which might be to much work for the whole thing. you could always just open up the intake manifold so that it matches the heads better. just my .02, wait for some more opinions.
'02 Mustang GTm Convertible - N/A Cammed Daily '88 Mustang GTm - 1/4 Mile Build - 750rwhp Project '97 Saturn SL2m - Ex-Nitrous Build - Back-Up Daily |
1991 Ford Mustang GT
do you have the intake gaskets inplace when you tested it ? if its off by a little bit, dont worry, when you tighten the bolts it should just about line up.
I have AFR 185 heads and trick flow R intake and that intake is recomended to be used with trick flow heads for port alignment. but mine lined up almost perfect once i trimed the gaskets
Mustang Fanatic
1989 Mustang LX
Aw, see I didn't tighten it down, the gaskets were In place but I just sat it on and put a few bolts to see how it would line up.... Trickflow R should be similar to mine right? Bottom anyway? Thnx for the input guys
It will line up better when its tightened down..i have the 185's and the TH intake...no issues.
95 GT- AFR 185's, Comp CAM, Trick FLow TH upper and lower, 30lb injec, 76MM C&L kit, Full MSD, BBK Pulleys, 3:73, BBK Long Tubes, X Pipe, Magnaflow Cat back, Cobra front control arms, MM CC plates LCA's and Panhard bar, tuned by Adam @ Pops Racing. |
Mustang Fanatic
1989 Mustang LX
Sweet. What cam are you running?
I went with the xe274.. How's the car run? Any 1/4 times?
#7 | |
She finally runs good...it took me a long time to get a good tune on it, but thanks to Adam @ Pops Racing its good now. As soon as i got a good tune loaded my fuel pump gave up..its been on jack stands for about 3 weeks...i will be ordering the new pump soon.. No trips to the track yet, but i will soon... I think i would have more power if i had gotten the 165's, but my plan to add a charger or stroke made me get the 185's...they are a little big for my current combo, but should be perfect when its all said and done.
#8 | |
98 Cobra
Mustang Fanatic
1989 Mustang LX
That's why I got 185s too.
I got the probe street fighter 347 .. I even got the 72cc heads cause I wanted to go with a Novi2000, but I got a deal on a vortech s trim...
#10 | |
89 GT
prolly bout 310 RWHP...last dyno run prior to my new and better tune was 302.3 RWHP...car is more lively and with much better drive-ability now...EEC Analyzer datalogs say about 361 crank..
Yeah, different people go either way...i do recall seeing a MMFF article about heads and the motor they used was almost identical to mine..the 165's put down around 15hp more at peak than the 185's did...who knows..i know i wouldn't want the 165's when i go 347 or SC
No PTV issues..i thought i was going to have to notch my pistons, but the cam we selected prevented me from having too without costing much power.
Threads Similar to: Trick Flow track heat intake on AFR 185's
| Trick Flow Track Heat Intake Manifold | SNmustang95 | 5.0 Mustangs | 20 | May 21st, 2011 09:03 PM |
| Trick Flow Track Heat Intake | BadBlackGT | 5.0 Mustangs | 12 | August 30th, 2010 08:50 PM |
| Trick Flow Track Heat vs. Explorer Intake | lakefrontlivin | 94-95 | 16 | February 18th, 2010 11:13 AM |
| Trick Flow Track Heat vs. Explorer Intake | lakefrontlivin | 5.0 Mustangs | 46 | February 12th, 2010 08:04 AM |
| New Trick Flow Track Heat Intake | cowboyup351 | 5.0 Mustangs | 9 | March 31st, 2009 12:06 PM |
