07 Turbo Focus
12.93 @ 105mph
Rear Suspension help
I'm setting the rear suspension for drag racing and I'm not sure on what spring I should go with. I have the other parts in already, just can't decide on a spring to match them. I did some searches online and found mixed reviews of what works with what setup and everything just seems so vague.
I've been considering 3 options; 1) keep the OEM springs, 2) Moroso trick drag springs, or 3) Steeda progressive rear drag springs. From what I've read, the Moroso springs make the car actually sit slightly higher and don't do much better performance wise vs the stock suspension. I've also read that the Steeda springs are too stiff and without an anti-roll bar, won't do much good. Due to the cons of both of them, I've been considering just sticking with the OEM springs, but I do want a little better performance. The current setup is all stock 4 cylinder suspension. What will be going in next weekend will be UPR adjustable upper and lower control arms and Strange 10 way adjustable shocks. The car is a stock long block 5.0L 302 carb'd with full bolt-ons. The stock E7 heads are slightly ported. I have an AOD with TCI "Saturday Night Special" torque converter, external fluid cooler, and Silverfox SPT-1 valve body. The rear end is an 8.8" rear with 4.10s, t-lok, c-clip eliminators, Moser 28 spline axles, and extended studs. With that setup, I plan to launch on the car pretty hard so I'm looking for what spring is going to work best for those hard launches with the other suspension parts mentioned above. Thanks in advance.
2007 Focus - 230/215, cams/head/manifold swap done, new #s soon ...going E85! 1985 Bronco - 351W & 4WD 1986 Mustang LX - 351W build in the works! David Michael Smith, 07/25/1956 - 12/08/2011 ...R.I.P dad! I miss you dearly! Last edited by RDY4WAR; August 10th, 2011 at 11:50 AM. |
Proud American
Springs are not as important as geometery. If you look at baseline suspensions relocated upper control arms that really improved my car. My car 60' the exact same every pass on the same tune up. He has some really really good information on his website aswell on how to set the cars up.
07 Turbo Focus
12.93 @ 105mph
Gotcha. Yeah, I just got off the phone with UPR and they advised to just keep the OEM springs and worry more with the shocks and control arms. Just put a bag in the passenger side rear to combat the roll.
2007 Focus - 230/215, cams/head/manifold swap done, new #s soon ...going E85! 1985 Bronco - 351W & 4WD 1986 Mustang LX - 351W build in the works! David Michael Smith, 07/25/1956 - 12/08/2011 ...R.I.P dad! I miss you dearly! |
Priest of the Car Gods
I know Team Z's recommendation is the stock spring with a coil cut off.
Threads Similar to: Rear Suspension help
| Rear Suspension | mustang fanatic | 2005 - 2010 | 6 | February 25th, 2008 10:38 PM |
| rear suspension | angermgt | 5.0 Mustangs | 1 | July 30th, 2007 12:05 AM |
| Rear Suspension Help | sn-95aac | 5.0 Mustangs | 3 | October 7th, 2006 06:30 PM |
