93 5.0 upper intake questions
I would like to put gt40x ford racing heads and a cobra upper intake with a 70mm tb. Is this possible? I'd like to put in a e303 cam too. What else would I need to make this possible
1991 Ford Mustang GT
yes but the cobra intake only has a 65mm opening where the TB gets bolted to it, so if you want to use a 70mm TB then port the intake to that size. Other wise the 70mm TB is pointless if it flows into a smaller opening. I hope that was clear enough.
As for the E303 came.....BAD CHOICE All the A,B,C,D-----Z303 cams ( no good ) It is out dated and there are better cams out there....That cam was made back in the early 90s, cam teck has come along way in 20 years
Mustang Fanatic
1989 Mustang LX
Ryanw is right about the throttle body. It won't flow any better than a 65 in your case but you can always upgrade your intake later..
As for cam, e cam is alright but I gurantee you'll be happier with a TFS1 cam. Good power and perform well all around.. But you can always step up to comp cams...
89 Mustang LX: 347 AFR Comp Cam TFS Track Heat 359rwhp 395rwtq
the Cobra/GT40 and Explorer upper intakes have TB opsnings that are 70mm. Some are a tad (1mm) less, but all I have measured are larger than 65mm.
88 GT Vert 5spd, 3:73 gears, Explorer intake/65mm TB, Explorer Ps, Manley race 1.85/1.55 valves, 1.7/1.6 stud rockers, stock cam +4 degrees, MAC Jet-Hot coated shorties. 277RWHP/330RWTQ www.fastlanecars.com http://tmossporting.0catch.com/
i wish i had measured my old cobra intake be fore i ported it, but i remember porting the hell out of it to make it match my 70mm TB. Any ways it doesnt matter now. Good luck with your project
im selling elderblock performer lower and upper intake with 65mm tb along with a e303 cam interested??
Threads Similar to: 93 5.0 upper intake questions
| Gt40 upper intake QUESTIONS need answer quick | SlaXX | 5.0 Mustangs | 17 | October 13th, 2010 07:58 PM |
| upper intake... | Hunt_chevs | 5.0 Mustangs | 2 | March 30th, 2008 06:28 PM |
| Need help using a 5.0 upper intake on a 5.8 lower intake | Washington5.0 | 5.0 Mustangs | 4 | March 9th, 2007 01:54 AM |
